On 10/07/2012 at 02:43, xxxxxxxx wrote:
I'm trying to crate a spline, however, I seem to mess up local / global positions. Here is what I do. I have three Null objects and their global positions. Now the spline should start at p1 and end at the middle between p2 en p3 (=(p2+p3)/2). I create a spline, calculate the step per frame (midstep = midpoint* (frame/20.0) + p1). Everything is ok, when p1 is at 0,0,0. If not, it fails.
Any ideas? Here is the source.
import c4d #Welcome to the world of Python
def main() : pass #put in your code here
op1 = doc.SearchObject("p1") p1 = op1.GetMg().off op2 = doc.SearchObject("p2") p2 = op2.GetMg().off op3 = doc.SearchObject("p3") p3 = op3.GetMg().off midpoint = (p3 + p2) / 2 #print midpoint
frame = doc.GetTime().GetFrame(doc.GetFps()) if ((frame == 1) and (doc.SearchObject("EigenSpline") == None)) : print "Create Spline." splineobj = c4d.BaseObject(c4d.Ospline) # Create new spline splineobj[c4d.ID_BASELIST_NAME] = "EigenSpline" doc.InsertObject(splineobj) c4d.EventAdd()
current = splineobj.GetPointCount() splineobj.ResizeObject(1) splineobj.SetPoint(0, p1)
splineobj.Message (c4d.MSG_UPDATE) #update spline in viewport else: if (frame > 1) : splineobj = doc.SearchObject("EigenSpline")
splineobj.ResizeObject(frame) #add point
midstep = midpoint* (frame/20.0) + p1 splineobj.SetPoint(frame-1, midstep) splineobj.Message (c4d.MSG_UPDATE) #update spline in viewport
On 10/07/2012 at 03:58, xxxxxxxx wrote:
Solved. The algorithm was wrong, also to difficult. It should be: midstep = (midpoint - p1) * (frame/20.0) + p1
