Neighbor class and disconnected polygons
    On 03/08/2012 at 10:33, xxxxxxxx wrote:
    Just for completeness, here is the latest in-use code...
    class ConnectedPolyGroup
    private:
      Bool        m_bInit;
      LONG        m_numVerts;
      LONG        m_numPolys;
      LONG        m_numMappedPolys;
      LONG        m_GroupCount;
      CPolygon    *m_pDstPolys;
      UCHAR        *m_pDstPolyProcessed;
      UCHAR        *m_pNeighborsAdded;
      LONG        *m_pGroupIDs;
      Neighbor    m_dstNbr;
      Bool ProccessConnectedPolys(void);
    public:
      void FreeData(void);
      BaseSelect *SelectGroup(LONG GroupID);
      LONG NumPolys(void)                        { return m_numPolys; }
      LONG NumConnectedGroups(void)            { return m_GroupCount; }
      LONG GroupID(LONG polyNdx)                { if(!m_bInit || polyNdx >= m_numPolys) return NOTOK;    return  m_pGroupIDs[polyNdx]; }
      Bool Init(PolygonObject *pPolyObj);
      ConnectedPolyGroup(void);
      ~ConnectedPolyGroup(void);
    ConnectedPolyGroup::ConnectedPolyGroup(void)
      m_bInit = false;
      m_GroupCount = 0;
      m_pDstPolyProcessed = NULL;
      m_pNeighborsAdded = NULL;
      m_pGroupIDs = NULL;
    ConnectedPolyGroup::~ConnectedPolyGroup(void)
      this->FreeData();
    void ConnectedPolyGroup::FreeData(void)
      bDelete(m_pDstPolyProcessed);
      bDelete(m_pNeighborsAdded);
      bDelete(m_pGroupIDs);
      m_numMappedPolys = 0;
      m_GroupCount = 0;
      m_numVerts = 0;
      m_numPolys = 0;
      m_bInit = false;
    // generate a BaseSelect based on connected GroupID - caller owns returned BaseSelect pointer
    BaseSelect *ConnectedPolyGroup::SelectGroup(LONG GroupID)
      if(!m_bInit || GroupID >= m_GroupCount)    return NULL;
      BaseSelect *pSel = BaseSelect::Alloc();
      if( !pSel )                                return NULL;
      pSel->DeselectAll();    // <-- shouldn't actually be needed
      LONG polyNdx;
      for(polyNdx=0; polyNdx<m_numPolys; polyNdx++)
          if( m_pGroupIDs[polyNdx] == GroupID )
              pSel->Select(polyNdx);
      return pSel;
    Bool ConnectedPolyGroup::Init(PolygonObject *pPolyObj)
      this->FreeData();
      m_numVerts = pPolyObj->GetPointCount();
      m_numPolys = pPolyObj->GetPolygonCount();
      m_pDstPolys = pPolyObj->GetPolygonW();
      // track which polys have been processed.
      m_pDstPolyProcessed = bNew UCHAR[m_numPolys];
      if( !m_pDstPolyProcessed )        return false;
      // track which polys have had their neighbors added.
      m_pNeighborsAdded = bNew UCHAR[m_numPolys];
      if( !m_pNeighborsAdded )        return false;
      // track which 'connected group' each poly belongs to
      m_pGroupIDs = bNew LONG[m_numPolys];
      if( !m_pGroupIDs )                return false;
      // initialize Neighbor class
      if( !m_dstNbr.Init(m_numVerts, m_pDstPolys, m_numPolys, NULL) )    return false;
      ClearMem(m_pDstPolyProcessed, m_numPolys * sizeof(UCHAR), 0);
      ClearMem(m_pNeighborsAdded, m_numPolys * sizeof(UCHAR), 0);
      ClearMem(m_pGroupIDs, m_numPolys * sizeof(LONG), 0);
      LONG polyNdx;
      Bool done = false;
          if( m_pDstPolyProcessed[polyNdx] )    continue;
          m_pGroupIDs[polyNdx] = m_GroupCount;                        // set group index/ID
          m_pDstPolyProcessed[polyNdx] = 1;                            // mark this one off...
          m_numMappedPolys++;
          done = this->ProccessConnectedPolys();                        // set all neighbors to same group index/ID
          m_GroupCount++;                                                // bump group index/ID for next group
          if( done )    break;
      // done with these...
      m_bInit = true;
      return true;
    Bool ConnectedPolyGroup::ProccessConnectedPolys(void)
      Bool morePolys = true;
      while( morePolys )
          morePolys = false;
          LONG polyNdx;
              if( !m_pDstPolyProcessed[polyNdx] )    continue;    // only adding/processing neighbors of previously matched/valid polys
              if( m_pNeighborsAdded[polyNdx] )    continue;    // don't add/process neighbors if already added
    //            CPolygon *pDstPoly = &m_pDstPolys[polyNdx];
              PolyInfo *pDstPolyInfo = m_dstNbr.GetPolyInfo(polyNdx);
              LONG side;
              for(side=0; side<4; side++)
                      LONG dstNbrNdx = pDstPolyInfo->face[side];
                  if( dstNbrNdx == NOTOK )                continue;    // skip any sides that don't exist
                  if( m_pDstPolyProcessed[dstNbrNdx] )    continue;    // only adding neighbors not already added
                  m_pGroupIDs[dstNbrNdx] = m_GroupCount;        // all connected polys get the same index/ID
                  m_pDstPolyProcessed[dstNbrNdx] = 1;            // mark this one off...
                  m_numMappedPolys++;
                  morePolys = true;                            // since we added / processed another poly, make sure we loop again to get _it's_ neighbors
              m_pNeighborsAdded[polyNdx] = 1;                    // we've processed this polys neighbors
              if( m_numMappedPolys == m_numPolys )
                  morePolys = false;
                  break;    // return true?
          return true;
      return false;
    ...I _think_ the only difference in that and what's posted above is that I go ahead and free a couple (no-longer-needed) arrays inside Init() instead of waiting for the Destructor.
    As an aside, based on some later use of this base code (in this thread), I think that I determined that I didn't really need the m_pNeighborsAdded array/checking/tracking at all.
    On 04/08/2012 at 07:55, xxxxxxxx wrote:
    Will compare code and update as needed.  Thanks!
