On 29/06/2012 at 09:01, xxxxxxxx wrote:
Cinema 4D Version: All
Platform: Windows ;
Language(s) :
I don't know if I'm doing something wrong.
But I cannot make the MultiLineEdit textbox scale with the window.
When I create the code in res edit it works fine.
But when I use the files that res edit generates in C4D R12 or R13. It no loner works.
Since my plugin is a GeDialog type of plugin. I thought perhaps the dialog type plugins don't support the .res file code for this particular behavior.
So I also tried using the AddMultiLineEditText() function in the CreateLayout() method. And it doesn't work there either: -BFH_SCALE <-----Doesn't Work ``-BFV_SCALE <-----Doesn't Work
-BFH_SCALEFIT <-----Doesn't Work
-BFV_SCALEFIT <-----Doesn't Work
It's very important to the way my plugin works that MultiLineEdit textbox shrinks and grows with the window. But nothing I do makes it work.
It appears to be either a bug. Or an undocumented MultiLineEdit textbox limitation.
