On 27/06/2012 at 17:23, xxxxxxxx wrote:
Hi, I am almost new to scripting in C4D, but not new to programming. I want to use the User Data Spline interface, and wonder how I can read out the values. I have added a null object to my project. To this object I added an xpresso tag. In the xpresso I added a Python operator. The Python operator has one user data value, with a Spline interface.
Now - how do I read out the values from this interface? I guess C4D does the math behind the scenes for me? So that I can get the Y value for any given X value between 0 (min) and 1 (max).
Any help much appreciated!
-Ingvar
On 27/06/2012 at 17:50, xxxxxxxx wrote:
For simplicity, add your position controller and the Spline as Userdata on the xpresso tag. The nodes already have a SplineData input (I called "curve" in the example).
Cheers Lennart
On 27/06/2012 at 18:28, xxxxxxxx wrote:
Hej Lennart, tack söta bror!!!! Just great. Having searched for this several hours, you came up with the solution in minutes! As a matter of fact, I want to wrap everything in a Python script, and not use xpresso operators at all. So I use this code: foo = op[c4d.ID_USERDATA,1] somePosition = 0.6 print int(foo.GetPoint(somePosition).y * 100) This gives me the percentage at position 0.6, where the spline user data scale is Max 1 on the X-axis and Max 1 on the Y axis. Precisely what I am after. The Spline User Data control is invaluable, and now I know how to use it Thanks again for your help! -Ingvar
