On 16/06/2012 at 13:38, xxxxxxxx wrote:
Cinema 4D Version: 12
Platform: Windows ;
Language(s) : C++ ;
I'm having problems with the DoCommand() method in my tool plugin.
All I want to do is use the SendModelingCommand to delete the selected polygon in my tool.
I select the polygon in my MouseInput() method.
Then I call to the DoCommand() to execute it and delete the polygon. But it doesn't do anything.
The MouseInput code :
BaseContainer state;
while (GetInputState(BFM_INPUT_MOUSE, BFM_INPUT_MOUSELEFT, state)) //While the LMB is down
if (state.GetLong(BFM_INPUT_VALUE) == 0) break; //If the state value is 0. The LMB is no longer down..so don't enter the loop
LONG x = state.GetLong(BFM_INPUT_X); //Get the cursor's X screen coordinates
LONG y = state.GetLong(BFM_INPUT_Y); //Get the cursor's Y screen coordinates
GeShowMouse(MOUSE_POINT_HAND); //Change the cursor's apperance when the mouse button is down
//Check if there is a valid poly id, otherwise deselect all polygons
if(polygonid>-1)
bs->Select(polygonid); //Select the polygon that's currently highlighted
ModelingCommandData mdat;
BaseContainer bc;
mdat.bc = &bc;
DoCommand(mdat); //Call to the DoCommand and execute it
else bs->DeselectAll();
The DoCommand code :
Bool PolygonTool::DoCommand(ModelingCommandData &mdat)
BaseObject *op = mdat.doc->GetActiveObject();
PolygonObject *objPoly=(PolygonObject* )op;
mdat.mode = MODELINGCOMMANDMODE_POLYGONSELECTION; //Use this for dealing with polygon selections
mdat.flags = MODELINGCOMMANDFLAGS_CREATEUNDO;
GePrint("Am I working?"); //This prints fine
if (!SendModelingCommand(MCOMMAND_DELETE, mdat)) return FALSE;
GePrint("Am I still working?"); //<-----------Does not print!!
EventAdd();//Update all the changes
return TRUE;
Notice that after the SendModelingCommand() code. Something bad happens and the last print does not work. I don't know if that has anything to do with the problem or not.
What am I doing wrong?
