On 13/06/2012 at 11:33, xxxxxxxx wrote:
Is there a way to have Python pause for user input and then act on that input?
For example I would like to start a script, press a number, then a comma, then another number and then 'shift' to set the render frame range. Maybe not the most useful example, but you get the idea.
Here is a bit of code to look for the shift part, but I still don't know how to capture the number input first:
# Check for modifier keys bc = c4d.BaseContainer() if c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD,c4d.BFM_INPUT_CHANNEL,bc) : if bc[c4d.BFM_INPUT_QUALIFIER] & c4d.QSHIFT: shiftMod=1 if shiftMod==1: .....
I would also like to start a script, get the current snap settings, let the user create a two point spline, then use that splines point data to print out a distance measure, and finally delete the spline. This would make a quicker measure tool.
I'm starting to be fairly proficient at manipulating the data with Python, but am falling short at interactivity with the user. Anyone?
On 14/06/2012 at 10:54, xxxxxxxx wrote:
The Py4D Console in Cinema 4D is only for stdout and does not accept input while running a script. You can however use a dialog for this. There are built-in methods that show various dialogs.
import c4d input = c4d.gui.InputDialog()
I don't know if it's a bug, but you will not be able to recognize when the user clicks 'Cancel' on this dialog. Just cancel your script if the user enters nothing.
import c4d def main() : input = c4d.gui.InputDialog() if not input: c4d.gui.MessageDialog("Script canceled.") return # actually only necessary if code follows this if-clause else: c4d.gui.MessageDialog("You've entered: %s" % input) main()
On 14/06/2012 at 12:09, xxxxxxxx wrote:
Thanks Nik. I have been learning about dialogs today and have run a couple scripts that hung C4D because of no 'cancel' button. Maybe it's because I'm using R12? I will be using your 'cancel' code. Anyways I'm currently struggling with trying to make tabs such as with:
import c4d from c4d import gui def main() : gui.GeDialog.TagGroupBegin(id=5670,BFH_LEFT[,tabtype=TAB+TABS]) if __name__=='__main__': main()
I know that I'm missing some important code to initialize the tabbed dialog, but since I'm a beginner, I'm not sure what. Do you suggest looking into the C++ SDK for more info? Edit: I'm checking out the SDK now trying to figure out how to translate the C++ code to Python. Are there any resources for learning to do this that you know of?
On 15/06/2012 at 07:15, xxxxxxxx wrote:
Hi visualride,
What do you mean with "no cancel button"? I guess you are using a Mac? May you post a screenshot of the dialog that does not own a cancel button, please?
So, you want to make your own dialog?
There are some examples in the SDK that should at least give you a hint how to use it. There are also various posts on the forum on dialogs. Here is a little example:
# author: Niklas Rosenstein <[email protected]> import c4d class InputDialog(c4d.gui.GeDialog) : INPUT = 10000 BTNOK = 10001 BTNCNCL = 10002 def __init__(self, title=None, input_text=None) : self.title = title or "User Input" self.input_text = input_text or "" self.result = None def CreateLayout(self) : FULLFIT = c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT self.AddEditText(self.INPUT, FULLFIT) self.GroupBegin(0, FULLFIT) self.AddButton(self.BTNOK, FULLFIT, name="OK") self.AddButton(self.BTNCNCL, FULLFIT, name="Cancel") self.GroupEnd() return True def InitValues(self) : self.SetTitle(self.title) self.SetString(self.INPUT, self.input_text) return True def Command(self, id, msg) : if id == self.BTNOK: close = True self.result = self.GetString(self.INPUT) elif id == self.BTNCNCL: close = True self.result = None else: close = False if close: self.Close() return True def open_input_dialog(default=None, title=None, width=200) : dialog = InputDialog(title, default) dialog.Open(c4d.DLG_TYPE_MODAL, defaultw=width) return dialog.result def main() : value = open_input_dialog("Enter Text.", "I'm waiting for your input.") if value is None: print "Cancelled." else: print "Input:", value main()
On 15/06/2012 at 15:32, xxxxxxxx wrote:
Thanks Niklas. This will be a big help. I haven't found those snippets of code that I used yesterday that brought up a dialog with the 'cancel' and 'minimize' buttons greyed out, but since it happened more than once I assume it was because of my version (R12) or that the code was written on a PC (I am using a Mac). If I do come across it again I will post it.
As I'm learning (I started sporadically about a month ago) I gain many more questions than I answer but it is fun, and hopefully it will even be practical soon.
