License server issue
On 15/06/2012 at 02:59, xxxxxxxx wrote:
Sorry I have no idea what could be the cause. Btw. 13.012 is the latest version of the LS.
cheers,
Matthias
On 15/06/2012 at 03:02, xxxxxxxx wrote:
thx Matthias for confirming. Yeah, as I wrote I can only conclude now that I am missing something somewhere on my side. It must be something stupid (although I just went thru the serial check code..which is fine..I now triple checked...this is not it), I miss the forest for the trees somehow. :-/
Anyway, thanks so far both of you. Once I have it sorted I'll report back.
On 15/06/2012 at 03:03, xxxxxxxx wrote:
...still lurking, but running low on suggestions...
Do you know if your plugin is failing to validate it? Or is the (successful) validation just not being honored by the LS?
What version are you building your plugin with? Have you tried sending him an R12 build (most R12 plugins will work fine with R13).
If R13.058, have you tried going back to R13.012?
On 15/06/2012 at 03:05, xxxxxxxx wrote:
yeah, tried both already the R12 and an exclusive R13 built. It must be my plugin that is failing somehow but the serial check is correct (it would be nice if I could remotely debug on his machine ^^). I'll now build a line-by-line print out. That should show me exactly WHAT is failing.
On 15/06/2012 at 03:26, xxxxxxxx wrote:
okay, shame on me and I probably indeed need a vacation. In the end it was not the plugin, it was not the license server, not the computers or C4D. It was human failure because it was me.
I forgot to clip 2 digits in the LS key and as I do this manually I didn't notice. Even worse, I compared the key to the keys of my other LS customers and I absolutely did not notice the difference! Unbeeeelievable...
this is the point where I would like to jump out of the window. sigh...I will now sit down and automate this step. Sorry for all the hassle...you now have 5 seconds to giggle :)
On 15/06/2012 at 03:49, xxxxxxxx wrote:
Well, I'm glad it was not something worse :)
cheers,
Matthias
On 15/06/2012 at 03:52, xxxxxxxx wrote:
Same here. ~giggle~
Glad you got it sorted out.
