On 11/06/2012 at 07:29, xxxxxxxx wrote:
User Information: Cinema 4D Version: R9.6+ Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ;
--------- Howdy,
I had an issue with this code:
Bool IsUsableCharacter(const String s) { if(s >= "a" && s <= "z") return TRUE; if(s >= "A" && s <= "Z") return TRUE; if(s >= "0" && s <= "9") return TRUE; if(s == "_") return TRUE; return FALSE; }
... where it returns FALSE for "z", "Z" and "9" if those characters are in the middle of the string but not if they are the last character in the string.
The fix was to change the code to this:
Bool IsUsableCharacter(const String s) { if(s > "`" && s < "{") return TRUE; if(s > "@" && s < "[") return TRUE; if(s > "/" && s < ":") return TRUE; if(s > "^" && s < "`") return TRUE; return FALSE; }
Why doesn't the first code work?
Adios, Cactus Dan
On 12/06/2012 at 00:58, xxxxxxxx wrote:
Sorry, I can't reproduce this problem. My test code worked fine. Can you post some code where you pass strings to the functions?
here my test code, small async dialog:
#define ID_ASYNCTEST 1000955 #include "c4d.h" #include "c4d_symbols.h" class AsyncDialog : public GeDialog { private: public: AsyncDialog(void); virtual Bool CreateLayout(void); virtual Bool InitValues(void); virtual Bool Command(LONG id,const BaseContainer &msg); }; enum { IDC_TEXT = 1000 }; AsyncDialog::AsyncDialog(void) { } Bool AsyncDialog::CreateLayout(void) { // first call the parent instance Bool res = GeDialog::CreateLayout(); SetTitle("GuiDemo C++"); GroupBegin(0,BFH_SCALEFIT,1,1,"",0); { GroupBorderSpace(4,4,4,4); AddEditText(IDC_TEXT, BFH_SCALEFIT, 400, 0, 0); } GroupEnd(); return res; } Bool AsyncDialog::InitValues(void) { // first call the parent instance if (!GeDialog::InitValues()) return FALSE; //SetString(IDC_TEXT, String("hello")); return TRUE; } Bool IsUsableCharacter(const String s) { if(s >= "a" && s <= "z") return TRUE; if(s >= "A" && s <= "Z") return TRUE; if(s >= "0" && s <= "9") return TRUE; if(s == "_") return TRUE; return FALSE; } Bool AsyncDialog::Command(LONG id,const BaseContainer &msg) { switch (id) { case IDC_TEXT: String text; GetString(IDC_TEXT, text); LONG len = text.GetLength(); for (LONG i=0; i<len; i++) { String subtext = text.SubStr(i, 1); if (IsUsableCharacter(subtext)) GePrint(subtext); else GePrint("fail"); } break; } return TRUE; } class AsyncTest : public CommandData { private: AsyncDialog dlg; public: virtual Bool Execute(BaseDocument *doc); virtual LONG GetState(BaseDocument *doc); virtual Bool RestoreLayout(void *secret); }; LONG AsyncTest::GetState(BaseDocument *doc) { return CMD_ENABLED; } Bool AsyncTest::Execute(BaseDocument *doc) { return dlg.Open(DLG_TYPE_ASYNC, ID_ASYNCTEST, 0, 0); } Bool AsyncTest::RestoreLayout(void *secret) { return dlg.RestoreLayout(ID_ASYNCTEST,0,secret); } Bool RegisterAsyncTest(void) { return RegisterCommandPlugin(ID_ASYNCTEST,GeLoadString(IDS_ASYNCTEST),0,NULL,String("C++ SDK Menu Test Plugin"),gNew AsyncTest); }
On 12/06/2012 at 05:48, xxxxxxxx wrote:
Howdy,
AHA! I was doing this:
String subtext = text.SubStr(i, len);
... instead of like your code:
No wonder it wasn't working.
On 12/06/2012 at 07:16, xxxxxxxx wrote:
Ah, good to hear it was a simple mistake.
