On 09/06/2012 at 03:27, xxxxxxxx wrote:
Trying to understand vectors, matrix, etc. I am trying to (re)place an object on a spline using the spline offset.
So, on frame x, the Sphere is placed on the spline using spline offset. On frame x+1, I want to position the sphere a bit further (randomly) on the spline, thus increase the spline offset a bit and replace the sphere. Now the question is, how to get the spline offset using the sphere position?
Below the code I use at this moment to calculate the spline offset given the sphere position and the 'origin' position of the spline (offset = 0).
For a straight spline it is ok, but when I change (round) the spline a bit, something goes wrong. After the next point, the position goes 'wild'. It seems that need to take the rotation into account, but how?
Another strange thing is, that when I do not use random, but just a standard offset (frame / 100.0) everything is ok?
---- Piece of code, see link for the complete file --- scene file: www.nfvc.nl/test - place object on spline.zip
#get offset on spline based on object position pos0 = sh.GetPosition(0) # get 'origin' position spline offset=0 objmtx = current_object.GetMg() # Get the object's global matrix diff = objmtx.off # get object position
dist = (diff-pos0).GetLength() # get difference between spline origin and object
currentoffset = sh.GetOffsetFromUnit(dist) # get offset on spline
Note: I can solve the issue by storing the spline offset at frame x and use it in frame x+1, but I really want to understand.
On 12/06/2012 at 05:12, xxxxxxxx wrote:
Just do as you have already stated in your 'note'. That is the way to handle it. The way you want to achieve it is absolutely unnecessary and impractical. It's also not very trivial. I'm not sure if there actually is a way to precisely calculate it, rather than going the iterative way.
-Nik
