On 05/06/2012 at 10:50, xxxxxxxx wrote:
Hello friends,
I am completely new to python scripting.
I am writing a script in c4d which allows me to apply materials randomly to a selection of objects and set the texture tag's rotation coordinates to random incrementals of 90 degrees.
I was able to figure out how to apply random materials to the selected objects however when i go to change the rotation values of the texture tags on the objects.... it is giving me unexpected results.
The resulting rotation numbers for X axis are very large like 10313.24 ° or, -5156.62 °; they should be 90, -90, 180, or 0.
Is this because of vectors?
If i can just change the rotation coordinates of the texture tags randomly by 90 degrees I would be happy.
here is my script so far: ------------------------------------------------------- import c4d import random import math from c4d import gui #Welcome to the world of Python
def main() : doc = c4d.documents.GetActiveDocument() objs = doc.GetActiveObjects(True); #Stores selected objects in vairable 'objs' mats = doc.GetActiveMaterials(); #Stores selected materials in variable 'mats' angles = [90,-90,180, 0]; numMats = len(mats) - 1; numangles = len(angles) - 1; for _obj in objs: doc.SetActiveObject(_obj,0); doc.SetActiveMaterial(mats[random.randint(0,numMats)],0); c4d.CallCommand(12169); # Apply tag = _obj.GetTag(5616); #Selects current objects texture tag doc.SetActiveTag(tag); #Selects the object's texture tag tag()[c4d.TEXTURETAG_PROJECTION]=3; #Sets projection to Cubic vec = c4d.Vector(angles[random.randint(0,numangles)], 0, 0); #Here I am changing the X vector only tag.SetRot(vec); print vec; c4d.EventAdd(); if __name__=='__main__': main()
I will greatly appreciate your help.
Thank you
On 05/06/2012 at 15:42, xxxxxxxx wrote:
It's most likely because your angles must be set as Radians.
Cheers Lennart
