R13.058 BaseSelect::GetRange()
On 02/06/2012 at 08:33, xxxxxxxx wrote:
Cinema 4D Version: 13.058
Howdy,After upgrading to the latest version of R13 (13.058), there was a change in the BaseSelect::GetRange() member function.
The previous function was:
Bool GetRange(LONG seg, LONG *a, LONG *b) const;
... and the new changed function is:
Bool GetRange(LONG seg, LONG maxElements, LONG *a, LONG *b) const; // pass maxElements to make sure the returned values for a and b are < maxElements or MAXLONGl for no additional checks
Is there any reason why the updated function could not have been written like this:
Bool GetRange(LONG seg, LONG *a, LONG *b, LONG maxElements=MAXLONGl) const;
... so that those of us plugin developers who are still supporting earlier versions of Cinema 4D would still have our plugin code working without needing to rewrite it?
Of course rewriting the code isn't all that difficult, because I can simply create a wrapper function for it:
Bool CDGetRange(BaseSelect *bs, LONG seg, LONG *a, LONG *b, LONG maxElem=CDMAXLONG); Bool CDGetRange(BaseSelect *bs, LONG seg, LONG *a, LONG *b, LONG maxElem) { #if API_VERSION < 13000 return bs->GetRange(seg,a,b); #else return bs->GetRange(seg,maxElem,a,b); #endif }
But I'm still curious why the new parameter wasn't added to the end with a default value?
Adios,
Cactus Dan
On 09/06/2012 at 08:48, xxxxxxxx wrote:
Howdy,
Well, as reported by a customer today, the BaseSelect::GetRange() function change causes a crash if a plugin is compiled for R13.058 and installed in an earlier version of R13.
So, the new question now is, could this crash issue have been avoided if the updated API function had been changed to:
... instead of adding the parameter in the middle of the parameter list?
Also, if I uninstall R13.058 and reinstall the older version (R13.016) and recompile my plugins with the earlier version will that cause any issues with using them in R13.058?
Adios,
Cactus Dan
On 13/06/2012 at 07:09, xxxxxxxx wrote:
I agree it's an annoyance but I guess it's just something that can always happen. I have to check if a 13.016 compiled plugin will cause any problems in 13.058.
In the end it's one of these annoyances to be dependent on the host API and to keep your own code up-to-date.
cheers,
Matthias
On 13/06/2012 at 07:31, xxxxxxxx wrote:
Howdy,
Well, instead of uninstalling R13.058, I reinstalled R13.016 in a different location, compiled the plugins there and then copied them to R13.058 and they seem to work properly.
So is there a compatibility built into the API for older versions?
Adios,
Cactus Dan
