Python Effector Falloff
    On 24/05/2012 at 16:15, xxxxxxxx wrote:
    Question!
    I make a brand new cloner, add a cube, then apply an Python Effector.
    I then set Python Effector's "Mode" to Full Control. I then go to falloff and  make the shape Linear.
    As I pass the python effector through the cloner, it has no visible effect.
    This works on 'parameter'. It also works on the Coffee Effector.
    Am I doing something wrong? Is there a work around where the Python Effectors Falloff gets applied?
    Thank you very much for your time.
    Chris Schmidt
    On 25/05/2012 at 12:24, xxxxxxxx wrote:
    Apparently this is a bug. (Thanks Rick)
    Might have to go with Coffee effector here.
    Is there any way to do a rangemapper function in Coffee? specifically feed in a spline?
