c4d.TEXTURETAG_MATERIAL
On 23/05/2012 at 23:57, xxxxxxxx wrote:
Dear Cinema4D Developers,
In ttexture.h,
TEXTURETAG_MATERIAL = 1010, // link
says that TEXTURETAG_MATERIAL takes a link as input. However, how can I implement this requirement using this command-line? I tried with c4d.DA_ALIASLINK but did not work.
ID_TEXTURETAGMATERIAL=c4d.DescID(c4d.DescLevel(c4d.TEXTURETAG_MATERIAL,c4d.DA_ALIASLINK,0))
What I want to do is to assign material " mat1 " to c4d.TEXTURETAG_MATERIAL that way. Is this possible? The entire script is shown below.
Thank you very much for your kind of help.
Ricardo.
from c4d import guidef CreateKey(op, id, value, frame) :
if not op.GetDocument() : raise Exception, "object must be in a document"# First check if the track type already exists, otherwise create it... track=op.FindCTrack(id) if not track: track=c4d.CTrack(op,id) op.InsertTrackSorted(track) curve=track.GetCurve() key=curve.AddKey(c4d.BaseTime(frame,doc.GetFps())) key["key"].SetValue(curve,value)
def main() :
fps=30
frame=180
doc.SetMaxTime(c4d.BaseTime(frame,fps))
doc.SetTime(c4d.BaseTime(frame,fps))# Materials: mat1=c4d.BaseMaterial(c4d.Mmaterial) mat1.SetName("MM1") mat1[c4d.MATERIAL_COLOR_COLOR]=c4d.Vector(1,1,0) doc.InsertMaterial(mat1) mat2=c4d.BaseMaterial(c4d.Mmaterial) mat2.SetName("MM2") mat2[c4d.MATERIAL_COLOR_COLOR]=c4d.Vector(1,0,1) doc.InsertMaterial(mat2) # Textures: mtag=c4d.TextureTag() # Create a new texture tag... # Cubes: cube=c4d.BaseObject(c4d.Ocube) cube.SetName("MyCube") cube.InsertTag(mtag) doc.InsertObject(cube) doc.SetActiveObject(cube) # The record command needs an active object... cube.Message(c4d.MSG_UPDATE) **ID_TEXTURETAGMATERIAL=c4d.DescID(c4d.DescLevel(c4d.TEXTURETAG_MATERIAL,c4d.DA_ALIASLINK,0))** ID_TEXTURETAGOFFSETX=c4d.DescID(c4d.DescLevel(c4d.TEXTURETAG_OFFSETX,c4d.DTYPE_REAL,0)) CreateKey(mtag,ID_TEXTURETAGOFFSETX,value=0.50,frame=10) CreateKey(mtag,ID_TEXTURETAGOFFSETX,value=0.70,frame=50) **CreateKey(mtag,ID_TEXTURETAGMATERIAL,value=mat1,frame=0)** cube.Message(c4d.MSG_UPDATE) c4d.EventAdd()
if __name__=='__main__':
On 24/05/2012 at 01:51, xxxxxxxx wrote:
You can simply assign the material to c4d.TEXTURETAG_MATERIAL like this:
mtag[c4d.TEXTURETAG_MATERIAL]=mat1
And CKey.SetValue() only works with float values:
You should use CKey.SetGeData() instead for the bitmap. I'll ask the developers if it's possible to make this work.
On 24/05/2012 at 09:59, xxxxxxxx wrote:
Dear Yannick Puech,
Thank you very much!
So, what I have to do is to modify the definition CreateKey by this one:
def CreateKey(op,id,value,frame) :
if not op.GetDocument() : raise Exception, "object must be in a document"# First check if the track type already exists, otherwise create it... track=op.FindCTrack(id) if not track: track=c4d.CTrack(op,id) op.InsertTrackSorted(track) curve=track.GetCurve() key=curve.AddKey(c4d.BaseTime(frame,doc.GetFps())) **if type(value)==int or type(value)==float:**
** key["key"].SetValue(curve,value)**
** else:**
** key["key"].SetGeData(curve,value)**Isn't it?
Thank you.
On 25/05/2012 at 00:37, xxxxxxxx wrote:
Yes, this should work as expected.
