On 06/05/2012 at 16:03, xxxxxxxx wrote:
User Information: Cinema 4D Version: 13 Platform: Windows ; Language(s) : C++ ;
--------- Hey guys,
I'm having some trouble with creating custom preferences. I'm using the example code that's in the docs to learn from. But I don't see anywhere in that example where it actually does anything. As a practice example. I tried to make the timeline's highlight option turn on/off with my custom entry. But it doesn't work. No errors..It just simply doesn't do anything.
Here's the .cpp code:
#include "c4d.h" #include "c4d_symbols.h" #include "lib_prefs.h" #include "prefsmyprefs.h" #include "..\..\..\..\modules\newman\res\description\prefstimeline.h" #define PLUGIN_ID 1025669 //A plugin id gotten from plugincafe.com #define MY_PREFS_DIALOG_ID 1026251 //A custom user container id gotten from plugincafe.com class MyPrefs : public PrefsDialogObject { INSTANCEOF(MyPrefs, PrefsDialogObject) public: virtual Bool InitValues(const DescID &id, Description* desc = NULL); virtual Bool Init(GeListNode* node); virtual Bool GetDParameter(GeListNode *node, const DescID &id, GeData &t_data, DESCFLAGS_GET &flags); virtual Bool SetDParameter(GeListNode *node, const DescID &id, const GeData &t_data, DESCFLAGS_SET &flags); virtual Bool GetDEnabling(GeListNode *node, const DescID &id, const GeData &t_data, DESCFLAGS_ENABLE flags, const BaseContainer *itemdesc); virtual Bool GetDDescription(GeListNode *node, Description *description, DESCFLAGS_DESC &flags); BaseContainer *GetMyPrefs(); static NodeData *Alloc() { return gNew MyPrefs; } }; Bool MyPrefs::InitValues(const DescID &id, Description *desc) { BaseContainer* bc = GetMyPrefs(); if (!bc) return FALSE; switch (id[0].id) { case PREF_MYPREFS_BOOL1: InitPrefsValue(PREF_MYPREFS_BOOL1,GeData(TRUE),desc,id,bc); return TRUE; } return TRUE; } Bool MyPrefs::Init(GeListNode* node) { InitValues(PREF_MYPREFS_BOOL1); return TRUE; } Bool MyPrefs::GetDParameter(GeListNode *node, const DescID &id, GeData &t_data, DESCFLAGS_GET &flags) { BaseContainer* bc = GetMyPrefs(); if (!bc) SUPER::GetDParameter(node,id,t_data,flags); switch (id[0].id) { case PREF_MYPREFS_BOOL1: t_data = bc->GetBool(PREF_TL_HIGHLIGHT,TRUE); flags |= DESCFLAGS_GET_PARAM_GET; return TRUE; //<----Is this Wrong??? } return SUPER::GetDParameter(node,id,t_data,flags); } Bool MyPrefs::SetDParameter(GeListNode *node, const DescID &id, const GeData &t_data, DESCFLAGS_SET &flags) { BaseContainer* bc = GetMyPrefs(); if (!bc) SUPER::SetDParameter(node,id,t_data,flags); switch (id[0].id) { case PREF_MYPREFS_BOOL1: bc->SetBool(PREF_TL_HIGHLIGHT,t_data.GetLong()); flags |= DESCFLAGS_SET_PARAM_SET; GeUpdateUI(); return TRUE; //<----Is this Wrong??? } return SUPER::SetDParameter(node,id,t_data,flags); } Bool MyPrefs::GetDEnabling(GeListNode *node, const DescID &id, const GeData &t_data, DESCFLAGS_ENABLE flags, const BaseContainer *itemdesc) { BaseContainer* bc = GetMyPrefs(); if (!bc) SUPER::GetDEnabling(node,id,t_data,flags,itemdesc); return SUPER::GetDEnabling(node,id,t_data,flags,itemdesc); } Bool MyPrefs::GetDDescription(GeListNode *node, Description *description, DESCFLAGS_DESC &flags) { if (!description->LoadDescription("Prefsmyprefs")) return FALSE; if ( flags & DESCFLAGS_DESC_NEEDDEFAULTVALUE ) { InitValues(PREF_MYPREFS_BOOL1,description); } flags |= DESCFLAGS_DESC_LOADED; return SUPER::GetDDescription(node, description, flags); } BaseContainer* MyPrefs::GetMyPrefs() { BaseContainer* bc = GetWorldContainerInstance()->GetContainerInstance(MY_PREFS_DIALOG_ID); if (!bc) { GetWorldContainerInstance()->SetContainer(MY_PREFS_DIALOG_ID, BaseContainer()); bc = GetWorldContainerInstance()->GetContainerInstance(MY_PREFS_DIALOG_ID); if (!bc) return NULL; } return bc; } Bool RegisterMyPrefs() { PrefsDialogObject::Register(PLUGIN_ID, MyPrefs::Alloc, GeLoadString(IDS_MYPREFS), "Prefsmyprefs", 0, PREFS_PRI_MODULES); return TRUE; }
AFAICT. This type of plugin uses descriptions to do it's work. And I'm guessing that the methods GetDParameter() & SetDParameter() are the heavy lifters that actually do the work to execute things that are enabled in the preferences?
Can anyone tell me what I'm doing wrong?
On 07/05/2012 at 01:22, xxxxxxxx wrote:
Could you send your plugin's source code at sdk_support[at]maxon.net?
On 07/05/2012 at 07:51, xxxxxxxx wrote:
I managed to figure out how it works late last night Yannick. To execute something with the prefs. example in the docs. The code to do something has to go in the SetDParameter() method where "flags |= DESCFLAGS_SET_PARAM_SET" is located.
