World Dynamics Cache Buttons
On 03/05/2012 at 10:11, xxxxxxxx wrote:
I see that FindSceneHook() has been added to R13 so we can set the project settings now.
I'm converting my C++ project settings code to python. But the only ones I can't figure out how to write are the two Dynamics cache buttons.
Example:
def main() :
  sh = doc.FindSceneHook(180000100)
  c4d.CallButton(doc,c4d.WORLD_CACHE_BAKE)  #Does not work
  c4d.CallButton(doc,c4d.WORLD_CACHE_CLEAR) #Does Not work
if __name__=='__main__':
Are these buttons supported?
If so...How do we execute them?
On 03/05/2012 at 16:54, xxxxxxxx wrote:
Never Mind. I managed to figure it out.
def main() :
  c4d.plugins.FindPlugin(c4d.PLUGINTYPE_SCENEHOOK)
  c4d.CallButton(sh, c4d.WORLD_CACHE_BAKE)   #Executes the Bake button
  c4d.CallButton(sh, c4d.WORLD_CACHE_CLEAR)  #Executes the Clear button
On 04/05/2012 at 05:13, xxxxxxxx wrote:
eh, sould have looked here first, i have answered the cgtalk post already, but IMHO your first
example is already almost correct, but you have to pass sh instead of doc. the script won't throw
an error, as doc a BaseDocument is also a BeseList2D, but CallButton expects the object which
contains the id passed as the second parameter, so you have to pass sh. it makes no sense to
define sh and then not not to use it.
the same goes for c4d.plugins.FindPlugin(c4d.PLUGINTYPE_SCENEHOOK) (plus this line doesn't
really make any sense to me, does this actually return a BaseList2D ?). also EventAdd() isn't
necessary in that case.
shortest form would be :
c4d.CallButton(doc.FindSceneHook(180000100), c4d.WORLD_CACHE_BAKE)
On 04/05/2012 at 08:41, xxxxxxxx wrote:
Now I can't figure out how to change any of the Key Interpolation settings.
  sh[c4d.TLWORLD_OVERDUB]=True  #Does Nothing!
On 04/05/2012 at 10:08, xxxxxxxx wrote:
180000100 is only the id to the MographDynamics hook if i am not mistaken, you have to get the id
of the Key Interpolation Tab from the ressource folder i think.
edit :
the  c4d console says  for KeyInterpolation :
[OK] KeyInterpolation
<c4d.BaseList2D object called 'Key Interpolation/Key Interpolation' with ID 465001535 at 0x10B54050>
i haven't tested / i am not quite sure if this is the correct id to get the hook.
On 04/05/2012 at 11:02, xxxxxxxx wrote:
Thanks. That is the correct ID#.
Here's a list of how to change all of the Project Settings:
##### Scene Scale & Units options
def main() :
  pScale = doc[c4d.DOCUMENT_DOCUNIT]    #Get the ProjectScale value
  value = c4d.UnitScaleData             #Create a UnitScaleData type variable
  pScale.SetUnitScale(1.0, c4d.DOCUMENT_UNIT_CM) #Change the Scene's scale and measure type settings
  doc[c4d.DOCUMENT_DOCUNIT]=pScale      #Make the changes happen from memory
  doc.Message(c4d.MSG_UPDATE)           #Update C4D about the changes
##### Project Settings
#Set up BaseTime so we can use it later on in the attributes
fps = doc.GetFps()
frame = doc.GetTime().GetFrame(doc.GetFps())
# doc[c4d.DOCUMENT_DOCUNIT]= See above
doc[c4d.DOCUMENT_FPS] = 30                           # Sets the FPS attribute
doc[c4d.DOCUMENT_TIME]= c4d.BaseTime(0, fps)         # The frame where the scrubber starts
doc[c4d.DOCUMENT_MINTIME]= c4d.BaseTime(0, fps)      # The start frame value
doc[c4d.DOCUMENT_MAXTIME]= c4d.BaseTime(90, fps)     # The end Frame value
doc[c4d.DOCUMENT_LOOPMINTIME]=c4d.BaseTime(0, fps)   # The Preview option Start time
doc[c4d.DOCUMENT_LOOPMAXTIME]=c4d.BaseTime(90, fps)  # The Preview option End time
doc[c4d.DOCUMENT_LOD]=1.0                      # Level of Detail
doc[c4d.DOCUMENT_RENDERLOD]=False              # Render LOD in Editor
doc[c4d.DOCUMENT_USEANIMATION]=True            # Use Animation
doc[c4d.DOCUMENT_USEEXPRESSIONS]=True          # Use Expressions
doc[c4d.DOCUMENT_USEGENERATORS]=True           # Use Generators
doc[c4d.DOCUMENT_USEDEFORMERS]=True            # Use Deformers
doc[c4d.DOCUMENT_USEMOTIONSYSTEM]=True         # Use Motion System
doc[c4d.DOCUMENT_DEFAULTMATERIAL_TYPE]= 1      # 0=WHITE, 1=GREY-BLUE, 2=USER
doc[c4d.DOCUMENT_CLIPPING_PRESET]=1            # 3=TINY, 0=SMALL, 1=MEDIUM, 2=LARGE, 4=HUGE, 5=CUSTOM
doc[c4d.DOCUMENT_CLIPPING_PRESET_NEAR]=1.0     # Sets the Near clipping value
doc[c4d.DOCUMENT_CLIPPING_PRESET_FAR]=100000.0 # Sets the Far clipping value
doc[c4d.DOCUMENT_LINEARWORKFLOW]=True          # Use Linear Workflow
doc[c4d.DOCUMENT_COLORPROFILE]=1               # 0=SRGB, 1=LINEAR, 2=DISABLED;
///// Info Settings
doc[c4d.DOCUMENT_INFO_AUTHOR]= ""     //Type your name in here
doc[c4d.DOCUMENT_INFO_COPYRIGHT]= ""  //Type your copyright info here
doc[c4d.DOCUMENT_INFO_README]= ""    // Type your notes here
///// Dynamics Settings
sh[c4d.WORLD_ENABLED]=True
sh[c4d.WORLD_DISABLE_DURING_LEAP]=True
sh[c4d.WORLD_TIMESCALE]=1.0
sh[c4d.WORLD_GRAVITY]=1000.0
sh[c4d.WORLD_DENSITY]=1.0
 //CACHE
fps = doc.GetFps()
c4d.CallButton(doc.FindSceneHook(180000100), c4d.WORLD_CACHE_BAKE)   //Executing the Bake dynamics cache buttons
c4d.CallButton(doc.FindSceneHook(180000100), c4d.WORLD_CACHE_CLEAR)  //Execute the Clear dynaimcs cache button
sh[c4d.WORLD_CACHE_USE]=False
sh[c4d.WORLD_CACHE_DISABLE_BAKED_OBJECTS]=False
sh[c4d.WORLD_CACHE_USE_TIME]=False
sh[c4d.WORLD_CACHE_TIME]=c4d.BaseTime(0, fps)
 //EXPERT
sh[c4d.WORLD_MARGIN]=1
sh[c4d.WORLD_SCALE]=100
sh[c4d.WORLD_CONTACT_RESTITUTION_LIFETIME]=5
sh[c4d.WORLD_SEED]=0
sh[c4d.WORLD_SUBSTEPS]=5
sh[c4d.WORLD_ITERATIONS]=10
sh[c4d.WORLD_ERROR_THRESHOLD]=10
 //VISUALIZATION
sh[c4d.WORLD_VISUALIZE]=False
sh[c4d.WORLD_VISUALIZE_SHAPES]=True
sh[c4d.WORLD_VISUALIZE_AABBS]=True
sh[c4d.WORLD_VISUALIZE_CONTACT_POINTS]=True
sh[c4d.WORLD_VISUALIZE_CONSTRAINTS]=True
  //Key Interpolation
sh = doc.FindSceneHook(465001535)
sh[c4d.TLWORLD_OVERDUB]=False
sh[c4d.TLWORLD_LOCKV]=False
sh[c4d.TLWORLD_AUTO]=True
sh[c4d.TLWORLD_LOCKTA]=False
sh[c4d.TLWORLD_BREAK]=False
//Spline types
sh[c4d.TLWORLD_INTER]=c4d.TLWORLD_INTER_SP  #Spline type
sh[c4d.TLWORLD_INTER]=c4d.TLWORLD_INTER_LI  #linear type
sh[c4d.TLWORLD_INTER]=c4d.TLWORLD_INTER_ST  #Step   type
sh[c4d.TLWORLD_LOCKT]=False
sh[c4d.TLWORLD_CLAMP]=True
sh[c4d.TLWORLD_LOCKTL]=False
sh[c4d.TLWORLD_KEEPVISUALANGLE]=False
