On 29/04/2012 at 14:53, xxxxxxxx wrote:
User Information: Cinema 4D Version: 13 Platform: Windows ; Mac ; Mac OSX ; Language(s) : C.O.F.F.E.E ;
--------- Is it possible to add a tag to an object my make it invisible in the Object Manager? For example, may I add a Tcoffeeexpression tag to an object but hide that tag?
Rui Batista
On 29/04/2012 at 16:00, xxxxxxxx wrote:
As far as I know. The only way to hide a tag with Coffee is to do it in a tag plugin like this: myTag::DisplayAllowed() { return FALSE; }
On 29/04/2012 at 16:28, xxxxxxxx wrote:
Thank you Scott. I already knew that one and I already used it in a tag that I created for one of my plugins. But what I need is to hide a COFFEE tag. I know that some tags are invisible by default. Could that be a bit that is set in the container of the tags?
On 29/04/2012 at 19:59, xxxxxxxx wrote:
I've never seen anything like that. Not even the C++ SDK. The only way I can see how to hide a tag like that is to: -Select the object and assign it to a layer -Select the tag and assign it to another layer -Solo the object's layer & lock the tag's layer
This is doable with C++ and Python. But I don't know about with Coffee. I seem to recall that Coffee had very limited layer support. But that was a while ago and I can't remember.
Probably not what you're wanting. But it's the only way I know how to hide tags at will like that. Maybe someone else will know a better way.
On 30/04/2012 at 01:41, xxxxxxxx wrote:
In C++ you can use the PLUGINFLAG_HIDE in the RegisterTagPlugin-Function.
On 30/04/2012 at 02:40, xxxxxxxx wrote:
And the method mentioned by Satara is basically 'permanent' since the tag is either visible or hidden for good when the plugin is registered at startup of C4D.
On 30/04/2012 at 03:05, xxxxxxxx wrote:
So, even if I set the PLUGINFLAG_HIDE with tag->SetBit(PLUGINFLAG_HIDE); it will not make it invisible?
