On 26/04/2012 at 04:57, xxxxxxxx wrote:
Hello everybody,
some days ago I started paying attention to plugin-writing. After several attempts, where I've struggled with the basic structure, I'm trying now for quite some time to bring a test project about that I thought it was quite easy. I want to create an information box in which the currently active object is always displayed. I began to try on CommandData and GeDialog, but unfortunately I didn't manage to update the dialog when the active object is changing. I've done it with ObjectData. Unfortunately, the update will only work as long as the dialog is in a window. If I integrate it into the layout of cinema, all the commands are executed correctly in the background (I´ve tried with 'print'), but the dialog isn't updated anymore. I think the cinemalayout itself has to be updated, because it works when I minimize cinema and then turn back to full-screen. How can I do that? I work with R12, window7/64bit.
I hope anyone can help... greetings rown
import os import math import sys import c4d from c4d import plugins, utils, bitmaps, gui # be sure to use a unique ID obtained from www.plugincafe.com PLUGIN_ID = 1000001 # TestID only!!!!!!!!!!! GR_T = 10001 TOBJ = 10002 OBJ = 10003 BOOL = 10050 # MyDialog class class MyDialog(gui.GeDialog) : name = "-" def CreateLayout(self) : self.SetTitle("rownTEST02") self.GroupBegin(id=GR_T, flags=c4d.BFH_LEFT, cols=2) self.GroupBorderSpace(10, 10, 10, 10) self.AddStaticText(id=TOBJ, flags=c4d.BFH_LEFT, initw=133, inith=10, name="Active Object", borderstyle=c4d.BORDER_NONE) self.AddStaticText(id=OBJ, flags=c4d.BFH_LEFT, initw=400, inith=10, name=self.name, borderstyle=c4d.BORDER_THIN_IN) self.AddCheckbox(id=BOOL, flags=c4d.BFH_LEFT, initw=120, inith=10, name="") self.GroupEnd() return True def InitValues(self) : self.IsActiveObj() self.SetString(OBJ, self.name) return True def Command(self, id, msg) : return True def IsActiveObj(self) : obj = c4d.documents.GetActiveDocument().GetActiveObject() if obj is None: self.name = "-" else: self.name = obj.GetName() class rownTEST02(plugins.ObjectData) : dialog = None def GetVirtualObjects(self, op, hierarchyhelp) : dirty = op.CheckCache(hierarchyhelp) or op.IsDirty(c4d.DIRTY_DATA) if dirty is False: return op.GetCache(hierarchyhelp) def __init__(self) : self.SetOptimizeCache(True) def Init(self, node) : return True def Message(self, node, type, data) : if type == c4d.MSG_MENUPREPARE: if self.dialog is None: self.dialog = MyDialog() self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=0, defaulth=0) elif type == c4d.MSG_GETCUSTOMICON: self.dialog.InitValues() return True if __name__ == "__main__": dir, file = os.path.split(__file__) icon = bitmaps.BaseBitmap() icon.InitWith(os.path.join(dir, "res", "icon.tif")) plugins.RegisterObjectPlugin(id=PLUGIN_ID, str="rownTEST02", g=rownTEST02, description="rownTEST02", icon=icon, info=c4d.OBJECT_GENERATOR)
On 26/04/2012 at 07:48, xxxxxxxx wrote:
Hi and welcome here!
In a CommandData you should be able to receive core messages (especially EVMSG_CHANGE) and update the active object name in your dialog:
def CoreMessage(self, id, msg) : if id==c4d.EVMSG_CHANGE: print "EVMSG_CHANGE" self.InitValues() return gui.GeDialog.CoreMessage(self, id, msg)
EVMSG_CHANGE core message is sent whenever a change is made in the scene.
Trying just to do that in an ObjectData plugin isn't the best place.
On 26/04/2012 at 13:14, xxxxxxxx wrote:
Hello Yannick,
thanks for bidding me welcome. :] You're right: Command Data, Core Message and EVMSG_CHANGE are the keywords. With the help of NoPhoto (c4dnetwork) I've found the solution and now it works. I wanted to know which messages are sent when, just to see if I can filter better. There are some IDs that I cannot identify (-24523562, 1018484, 1018490, 200000221). Does anyone know what they mean? And are there special IDs for ACTIVE_OBJCET_CHANGED(old coffee) or Point/Polygon-Selection-of-the-active-object-has-been-changed?
Here the Code:
import c4d from c4d import bitmaps, gui, plugins import collections, os # be sure to use a unique ID obtained from www.plugincafe.com PLUGIN_ID = 10000000 #TestID only!!!!!!!!!!!! GR_T = 10001 TOBJ = 10002 OBJ = 10003 def ActiveObjName() : str = "-" obj = c4d.documents.GetActiveDocument().GetActiveObject() if obj is None: str = "-" else: str = obj.GetName() return str # MyDialog class class MyDialog(gui.GeDialog) : def CreateLayout(self) : self.SetTitle("CommandData_Test") self.GroupBegin(id=GR_T, flags=c4d.BFH_LEFT, cols=2) self.GroupBorderSpace(10, 10, 10, 10) self.AddStaticText(id=TOBJ, flags=c4d.BFH_LEFT, initw=133, inith=10, name="Active Object", borderstyle=c4d.BORDER_NONE) self.AddStaticText(id=OBJ, flags=c4d.BFH_LEFT, initw=400, inith=10, name="", borderstyle=c4d.BORDER_THIN_IN) self.GroupEnd() return True def CoreMessage(self,id,msg) : if id == c4d.EVMSG_CHANGE: self.SetString(OBJ, ActiveObjName()) return True class CommandData_Test(plugins.CommandData) : dialog = None def Execute(self, doc) : if self.dialog is None: self.dialog = MyDialog() return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=0, defaulth=0) def RestoreLayout(self, sec_ref) : if self.dialog is None: self.dialog = MyDialog() return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref) if __name__ == "__main__": bmp = bitmaps.BaseBitmap() dir, f = os.path.split(__file__) fn = os.path.join(dir, "res", "icon.tif") bmp.InitWith(fn) plugins.RegisterCommandPlugin(id=PLUGIN_ID, str="CommandData_Test", info=0, help="CommandData_Test", dat=CommandData_Test(), icon=bmp)
On 26/04/2012 at 23:52, xxxxxxxx wrote:
EVMSG_CHANGE is the best message id to get notified when something has changed in the scene. Be careful to filter only message id you really know because core messages can be sent by 3rd party plugins and can be private too. GeDialog.CoreMessage() id parameter wasn't documented. This will be fixed in the next update of the docs.
On 27/04/2012 at 04:23, xxxxxxxx wrote:
Ok... I´ll filter in this way.
def CoreMessage(self,id,msg) : if id == c4d.EVMSG_CHANGE: if self.name != self.ActiveObjName() : self.name = self.ActiveObjName() self.SetString(OBJ, self.name) print "change" return True def ActiveObjName(self) : self.obj = c4d.documents.GetActiveDocument().GetActiveObject() if self.obj is None: str_ = "-" else: str_ = self.obj.GetName() return str_
till the next time and thanks a lot for comments, rown
