On 21/04/2012 at 11:19, xxxxxxxx wrote:
User Information: Cinema 4D Version: R13.051 Platform: Windows ; Language(s) : C++ ;
--------- I have no idea what's going on here, but every time I try and get the TP_MasterSystem of a scene, Cinema crashes straight away. This is my code and it's basically taken from the doc as is:
TP_MasterSystem* TPPartioData::GetTpMasterSystem(BaseDocument* doc) { if (!doc) { GePrint("No TP Master found"); return NULL; } BaseSceneHook* hook = doc->FindSceneHook(ID_THINKINGPARTICLES); if(!hook || hook->GetType() != ID_THINKINGPARTICLES) { GePrint("No TP Master found"); return NULL; } TP_MasterSystem *tp = (TP_MasterSystem* )(hook); // this is ok tp->NumParticles(); // here it crashes with _any_ tp->.... related call GePrint("I made it here"); // sadly, not so return static_cast<TP_MasterSystem*>(hook); }
I'm compiling with VS2008 for 64bit.
On 21/04/2012 at 11:27, xxxxxxxx wrote:
Ok, I don't really understand why and what it does, but I found this in an old thread and after adding it before the tp calls, it works now?
if (!CheckLib(ID_THINKINGPARTICLES, LIBOFFSET(C4DLibrary_TPOS, MSYS), reinterpret_cast<C4DLibrary\*\*>(&TPOS)))
{ GePrint("Checklib failed"); return FALSE; }
On 21/04/2012 at 11:31, xxxxxxxx wrote:
I wonder if you put
TP_MasterSystem *tp = (TP_MasterSystem* )(hook); if(!tp) return NULL;
if that would prevent the crash?
give it a try and let me know.
On 21/04/2012 at 15:01, xxxxxxxx wrote:
See InitThinkingParticles() in the SDK. You need to call this before TP is used (I'm just repeating the SDK when I say that!). I do it and don't have any problems with getting the TP master system.
Steve
On 21/04/2012 at 15:07, xxxxxxxx wrote:
I totally overlooked that! Thanks Steve
