keyframe an object in conjunction to another
    On 17/04/2012 at 02:41, xxxxxxxx wrote:
    Cinema 4D Version:   13
    Platform:      Mac OSX  ;
    Hi there,
    I have a problem with a script i've been working on. It is supposed to key object B if object A gets keyed using autmatic keyframing. therefore the script listens if at the current frame object A gets keyed and then uses a callcommand(12410) to keyframe object B.
    this works fine if i put the script in the scriptmanager and execute it manualy. but if i put it in a coffeetag so that it should execute automatically, it only works if object A already has had a key on this frame.
    hope that was understandable
    so heres the code:
    main(doc,op)
      if (op == doc->GetActiveObject()){
          var time = doc->GetTime();
          var fps= doc->GetFps();
          var currentFrame = time->GetFrame(fps);
          var track = op->GetFirstCTrack();
          var abordwhile;
          while (track && abordwhile!=true)// iterate through all recorded tracks
              if (track->GetName() == "Position . X" || track->GetName() == "Rotation . H") //only for position and rotation tracks
                  var curve = track->GetCurve(CCURVE_CURVE, FALSE); //Find the curve on a track
                  var keyTotal = curve->GetKeyCount();// count how many keys are on the track
                  var k;
                  for(k=0; k<(keyTotal); k++)// iterating through the keys to find which is on the current frame
                      var keytime = curve->GetKey(k)->GetTime()->GetFrame(fps);// get the frame K is on
                      if (keytime==currentFrame)// if the frame key k is on is the same frame the slider is on
                          k = keyTotal; // set k equal to the total number of keys on the track to stop the iteration through the keys
                          abordwhile = true; // stop iterating through the tracks
                          var Keythis1=doc->FindObject("Keythis"); //get the object, set it active and key it
                          if (Keythis1){
                              doc->SetActiveObject(Keythis1);
                              CallCommand(12410);
                              println("there should be a key now");
                              doc->SetActiveObject(op);
              track = track->GetNext();// go on and do the same thing to the next track until no more tracks are found
    Thanx,
    Bonzo
    On 17/04/2012 at 05:43, xxxxxxxx wrote:
    i guess the callcommand() is colliding ith the editor playback. this is how i would do it in python :
    from c4d import documents
    def main() :
        objA = doc.SearchObject("A")
        objB = doc.SearchObject("B")
        t = doc.GetTime()
        if (objA != None and objB!= None) :
            if hasKey(objA, t, ["Position . X","Rotation . H"]) :
                setKey(objB, t, ["X-Ray"])
    def hasKey (obj, time, tracknames) :
        for track in obj.GetCTracks() :
            for name in tracknames :
                if (name == track.GetName()) :
                    if (track.GetCurve().FindKey(time) != None) :
                        print 'Found key on {0}.{1} at {2}'.format(obj.GetName(), name, time.Get())
        return False
    def setKey (obj, time, tracknames) :
                    curve = track.GetCurve()
                    if (curve.FindKey(time) == None) :
                        key = c4d.CKey()
                        key.SetTime(curve, time)
    	            # as i am not sure how your key values are driven, you have to add some logic here
                        key.SetValue(curve, 0)
                        curve.InsertKey(key)
                        print 'Added key on {0}.{1} at {2}'.format(obj.GetName(), name, time.Get())
    On 17/04/2012 at 07:51, xxxxxxxx wrote:
    wow thank you. that is exactly what i was going for. only that yours is working ;)
    seems like i should dive more into python.
    thank you again!
    cheers,
    Bonzo
