On 09/04/2012 at 07:47, xxxxxxxx wrote:
Maxon, Please provide me(us) the python code to execute these buttons. They are executed differently from the other buttons.
Here is a C++ example of executing the Apply button on the TransformTool:
CallCommand(200000069); //Launch the Transfer Tool LONG tool_id = doc->GetAction(); //Get the active tool BasePlugin *tool = FindPlugin(tool_id, PLUGINTYPE_TOOL); //Get the tools id if (!tool) return FALSE; /////////// This section of code is used to execute the Apply button /////////////// BaseContainer bc(BFM_ACTION); //Create a container with an action id bc.SetLong(BFM_ACTION_ID, MDATA_TRANSFER_); //Executes the transfer tool's apply button bc.SetLong(BFM_ACTION_VALUE, TRUE); //Not sure if this is actually needed or not DescriptionCommand dc; dc.id = DescID(DescLevel(MDATA_APPLY, DTYPE_BUTTON, tool->GetType())); DescriptionCheckUpdate du; du.doc = doc; du.descid = &dc.id; du.drawflags = 0; tool->Message(MSG_DESCRIPTION_COMMAND, (void* )&dc); tool->Message(MSG_DESCRIPTION_CHECKUPDATE, (void* )&du); tool->Message(MSG_DESCRIPTION_USERINTERACTION_END); tool->Message(MSG_TOOL_RESTART); //////// End button code ///////////////////
Please provide me(us) with the python code version of this.
Thanks, -ScottA
On 10/04/2012 at 03:23, xxxxxxxx wrote:
The Python code is:
import c4d from c4d import plugins def main() : c4d.CallCommand(c4d.ID_MODELING_TRANSFER_TOOL) tool = plugins.FindPlugin(doc.GetAction(), c4d.PLUGINTYPE_TOOL) if tool is not None: c4d.CallButton(tool, c4d.MDATA_APPLY) c4d.EventAdd() if __name__=='__main__': main()
EDIT: I finally found how to make it work; I just missed c4d.EventAdd(). It's also missing in your C++ code.
And this code does nothing and isn't necessary:
Originally posted by xxxxxxxx /////////// This section of code is used to execute the Apply button /////////////// BaseContainer bc(BFM_ACTION); //Create a container with an action id bc.SetLong(BFM_ACTION_ID, MDATA_TRANSFER_); //Executes the transfer tool's apply button bc.SetLong(BFM_ACTION_VALUE, TRUE); //Not sure if this is actually needed or not
MDATA_TRANSFER_ marks the end of MDATA_TRANSFER's container entry enumeration; it's not a valid ID.
On 10/04/2012 at 08:07, xxxxxxxx wrote:
Thank You sir.
Please, please, please always include the button code to execute tools in the docs in the future. Every time they add a new tool. I have to contact support to ask how to execute them. I shouldn't have to bother you guys with such trivial questions.
BTW: This code also does not work in R12.
Keep up the good work Yannick, -ScottA
