Multiple individual chamfers problem
On 01/04/2012 at 02:27, xxxxxxxx wrote:
Take a square spline - 4 point
Its straightforward to globally chamfer all four points
or apply the chamfer to a particular point (by selecting it and not others - user data boolean)if chamfer_0_switch: sel.Select(0)
if chamfer_1_switch: sel.Select(1)
if chamfer_2_switch: sel.Select(2)
if chamfer_3_switch: sel.Select(3)but - how do you apply different chamfer radii to individual points
currently using
bc.SetData(c4d.MDATA_SPLINE_CHAMFERRADIUS, chamfer0)
u.SendModelingCommand(c4d.ID_MODELING_SPLINE_CHAMFER_TOOL, [obj],
c4d.MODELINGCOMMANDMODE_POINTSELECTION, bc, doc,
c4d.MODELINGCOMMANDFLAGS_CREATEUNDO)problem being - as soon as you apply the chamfer to a single point
the point count changestia
On 01/04/2012 at 02:49, xxxxxxxx wrote:
simply chamfer point by point ? as long as you are chamfering in ascending/descending point id order
you won't have any problems with your selection ids. each following selection id is n+1.
On 01/04/2012 at 03:03, xxxxxxxx wrote:
ie I need a point count dependent on chamfers selected
On 02/04/2012 at 01:41, xxxxxxxx wrote:
yes,
you could use a struct like approach. however you will have to make sure to chamfer in ascending
order with this approach.class IDRad() : def __init__(self, id=None, radius=None) : self.id = id self.radius = radius def main() : sel = [] counter = 0 sel.append(IDRad(0,5)) sel.append(IDRad(5,2)) sel.append(IDRad(10,4)) for n in sel: ChamferStuff(n.id+counter,n.radius) counter +=1 def ChamferStuff(id,Radius) : #doesomething
