On 22/03/2012 at 08:15, xxxxxxxx wrote:
Hi all hope your all haveing a great day just a small queston regarding shader nameing in python heres a example of script that works shd = c4d.BaseList2D(XSLANoise) what im looking for is the same line of script but for the Terrain Mask i tryed this but did not work shd = c4d.BaseList2D(XSLATerrainMask) or is the new Terrain Mask not yet supported or is there a totaly differrent name for this after the XSLA??????? Thank you all in advance for any insight to this. Cheers Ray.
On 22/03/2012 at 10:14, xxxxxxxx wrote:
i guess it is XTerrainmask. X is the prefix for shaders and sla a relict from xl 5 times when cinemas noise shaders were a plugin called Smells Like Almonds. you can always do a file search on your c4d/ressource folder to obtain correct ids or namings.
edit : from the *.res and *.h files
On 23/03/2012 at 10:22, xxxxxxxx wrote:
Thanks Devil for your reply but ive been through the .res and .h files xterrainmask is there but there seems to be no id given for it ive found all these but no xterrainmask.
Xcolor=5832, Xbitmap=5833, Xbrick=5804, Xcheckerboard=5800, Xcloud=5802, Xcolorstripes=5822, Xcyclone=5821, Xearth=5825, Xfire=5803, Xflame=5817, Xgalaxy=5813, Xmetal=5827, Xsimplenoise=5807, Xrust=5828, Xstar=5816, Xstarfield=5808, Xsunburst=5820, Xsimpleturbulence=5806, Xvenus=5826, Xwater=5818, Xwood=5823, Xplanet=5829, Xmarble=5830, Xspectral=5831, Xgradient=1011100, Xfalloff=1011101, Xtiles=1011102, Xfresnel=1011103, Xlumas=1011105, Xproximal=1011106, Xnormaldirection=1011107, Xtranslucency=1011108, Xfusion=1011109, Xposterizer=1011111, Xcolorizer=1011112, Xdistorter=1011114, Xprojector=1011115, Xnoise=1011116, Xlayer=1011123, Xspline=1011124, Xfilter=1011128, Xripple=1011199, Xvertexmap=1011137, Xsss=1001197, Xambientocclusion=1001191, Xchanlum=1007539, Xmosaic=1022119, Xxmbsubsurface=1025614, so im a but stuck at the moment any ideal what the id is. Cheers Ray
On 24/03/2012 at 02:45, xxxxxxxx wrote:
The X prefix is for 2D shaders that are used as Textures in Materials. Materials have an M prefix. Select a Terrain-shader (which is actually a material) and execute this script. You'll see:
import c4d mat = doc.GetActiveMaterial() tpe = mat.GetType() for k, v in c4d.__dict__.iteritems() : if v == tpe and k.startswith("M") : print k
On 24/03/2012 at 12:24, xxxxxxxx wrote:
Hi Niklas ye i agrree the terrain shader is a material but that is the old 1 thats been in cinama for donkeys years the one i cant get hold of is the brand new one that came with version 13 its the alttitude shader called Terrain Mask and shown in .res as xTerrainmask but i can not find the id numer for it in .h or .res unless im going blind lol if you can spot it many thanks. Cheers. Ray
On 01/04/2012 at 14:04, xxxxxxxx wrote:
You can find out the plugin ID for anything (objects, tags, shaders, materials, etc) by calling its GetType() method.
Or even easier: Create a material, add a Terrain Mask Shader. Click on the shader to see its attributes. Then drag the shader preview (the b/w gradient) into the Python console's input field and press Return. You'll get some information, including the plugin ID:
<c4d.BaseShader object called 'Terrain Mask/Terrain Mask' with ID 1026277 at 0x10eb41090 >
On 02/04/2012 at 09:59, xxxxxxxx wrote:
Hi thanks for that one Jack thumbs up. Cheers. Ray.
