Position Update
On 14/03/2012 at 10:39, xxxxxxxx wrote:
Hi all,
I'm trying to store all the positions by frame of an object to retry the distance traveled of this element, but I can't calculate the value at time of the position...
For more clarity here's my code:
def main() :
    fps     = doc.GetFps()
    frame = doc.GetTime().GetFrame(doc.GetFps())
    obj = op.GetObject()
    Distance = []
    currentTime   = doc.GetTime()
    for i in range (0, frame) :
        doc.SetTime(c4d.BaseTime(i,fps))
        print GPos # return always the same vector (obj position in current frame)
Distance.append(GPos)
        obj.Message(c4d.MSG_UPDATE)
        doc.SetTime(c4d.BaseTime(frame,fps)
    print Distance #contains always the same vector
I know that I have to update the scene before retry the object position(may be c4d.DrawViews command), but I don't know how.
Please help me :blush:
Luther
On 14/03/2012 at 15:37, xxxxxxxx wrote:
Hi Luther,
where does your GPos variable come from?
-Niklas
On 14/03/2012 at 23:39, xxxxxxxx wrote:
Hi Niklas,
I'm so sorry... when I cut and paste my code I always lost something :nerd:
GPos = obj.GetMg().off
Luther
On 15/03/2012 at 00:55, xxxxxxxx wrote:
Hi Luther,
I guess/hope you're doing that operation within the for-loop? Just a hint, why don't you use ~.GetAbsPos() ?
__
-Niklas
On 15/03/2012 at 02:35, xxxxxxxx wrote:
Hi Niklas,
I thought it was the same as GetAbsPos(). Isn't It?
What do you mean by "doing that operation within the for-loop?". for i in range(0,frame) is not a loop?
Luther
On 15/03/2012 at 06:04, xxxxxxxx wrote:
Hi Luther,
Yes it is, I just wondered why you do it this way. :) Yes it is a for-loop, but I wanted to know if you're calling op.GetMg().off within the for loop or not, i.e.
for i in range(frame) : # same as range(0, frame), better use xrange by the way
    GPos = op.GetMg().off
and not
But that would be too obvious I guess, and anyway, even if you're doing that, it won't work... I just tested it and saw that the position is not updated by just setting the document time, and I don't know how to update it .. I know there is a way to do it, but c4d.EventAdd() nor c4d.GeSyncMessage() seem to fix that... sry :D
-niklas
On 15/03/2012 at 06:40, xxxxxxxx wrote:
In Py SDK, documents -> BaseDocument at the end,
there is a example how to run thru the document.
Lennart
On 15/03/2012 at 07:06, xxxxxxxx wrote:
Hi Niklas,
thank you for your reply and your test...
Anyway, anyone knows the way to update a value in a given frame?
What is wrong in this code?
_
_
def main() :
    fps     = doc.GetFps()
    Distance = []
    for i in xrange (0, frame) :
        c4d.GeSyncMessage(c4d.EVMSG_TIMECHANGED)
        GPos = obj.GetAbsPos()
        doc.SetTime(c4d.BaseTime(frame,fps))
    print Distance # return a list of the same vector (in this case the position in the current frame)
 _
_
_
_
:cry:
Luther
On 15/03/2012 at 07:09, xxxxxxxx wrote:
Ops...
Hi Lennart, I wrote before read your post... I wil read the Sdk soon.
Thank you
Luther
On 15/03/2012 at 10:52, xxxxxxxx wrote:
@lennart: Ah right! I knew I saw it somewhere! Your mind is genius ;O
On 15/03/2012 at 11:37, xxxxxxxx wrote:
Hi Lennart, Niklas,
Its seems to me that it doesn't works... When I call "c4d.DrawViews" Cinema freeze.
May be I wrote somenthing wrong...
Here's my code:
_
_
from c4d import documents
def main() :
    fps     = doc.GetFps()
    Distance = []
        c4d.StatusSetBar(100*(i-0)/(frame-0))
        c4d.DrawViews(c4d.DRAWFLAGS_ONLY_ACTIVE_VIEW|c4d.DRAWFLAGS_NO_THREAD|c4d.DRAWFLAGS_NO_REDUCTION|c4d.DRAWFLAGS_STATICBREAK)
    c4d.EventAdd(c4d.EVENT_ANIMATE)
    c4d.StatusClear()
    print Distance
 _
_
On 15/03/2012 at 12:56, xxxxxxxx wrote:
That example is for a Command setup, not runtime/expression.
Typically to write to file and/or set keyframes etc.
If you need to check object position at different frame(s) from current
at runtime you might need to look into/use AnimateObject()
Lennart
On 15/03/2012 at 13:06, xxxxxxxx wrote:
So you want to compute the distance an object traveled within a PythonTag? Why didn't you say so earlier? :P
I don't know why you want to store the distance between each frame in a list, anyway, just create a global-variable and store your data there. Iterating over the full timeline each frame is quite imperformant..
import     c4d
data = dict( distance = 0,
           prevPos  = None )
def main() :
  position = op.GetOrigin().GetAbsPos()
  # Check for `None` explicit because `prevPos` could
  # be `c4d.Vector(0)` which evaluates to `False`, too.
  if data['prevPos'] is None:
      pass
      data['distance'] += (position - data['prevPos']).GetLength()
  data['prevPos'] = position
  print data['distance']
-Niklas
On 15/03/2012 at 13:31, xxxxxxxx wrote:
@ Lennart: Thanks for your reply, I will look immediately
@ Niklas: wow, you save my life :thumbsup: Thank you!!!!
On 15/03/2012 at 13:54, xxxxxxxx wrote:
For a bit of trivia in the matter, using the following
in a Py Generator (Optimize Cache Off) will animate
an animated object per frame and generate a spline of the path
and read the total length :)
Lennart
from c4d.utils import SplineLengthData
def main() :
    fps           = doc.GetFps()
    doctime       = doc.GetTime()
    currentframe = doctime.GetFrame(fps)
    start        = doc.GetMinTime().GetFrame(fps)
    end           = doc.GetMaxTime().GetFrame(fps)
    pspline       = c4d.BaseObject(c4d.Ospline)
    pspline.ResizeObject(end,0)
    obj = doc.SearchObject('Cube')# <- Animated Object
    for i in xrange(end) :
        doc.AnimateObject(obj,c4d.BaseTime(i, fps),c4d.ANIMATEFLAGS_0)
        pspline.SetPoint(i,obj.GetAbsPos())
    pspline.Message(c4d.MSG_UPDATE)
    sld = SplineLengthData()
    sld.Init(pspline,0)
    tot = sld.GetLength()
    print tot
    sld.Free()
    # Place obj back on track again
    doc.AnimateObject(obj,c4d.BaseTime(currentframe,fps),c4d.ANIMATEFLAGS_0)
    return pspline
On 15/03/2012 at 15:30, xxxxxxxx wrote:
wow Lennart,  I'm touched :slightly_smiling_face:
Thank you so much
On 16/03/2012 at 04:21, xxxxxxxx wrote:
Hi Lennart,
just to know, why this code doesn't work fine now? The "Distance"list store alway the same vector again...
def main() :
    fps     = doc.GetFps()
    Distance = []
    for i in xrange (frame) :
    print Distance
Luther
On 16/03/2012 at 07:00, xxxxxxxx wrote:
Please note that you must not call update functions or change the document structure within the execution functions of objects/tags/materials/... this might lead to crashs. From the c4d.threading module:
For all threaded functions it's forbidden to:
> 1. Add an Event.
> 2. Make any changes to materials.
> 3. Change the structure of objects attached to the scene.
> 4. Change parameters of elements attached to the scene (allowed, but not recommended except for tags).
> 5. Call a Draw function.
> 6. Perform any GUI functionality (e.g. displaying messages, opening dialogs etc.).
> 7. During drawing to do any file operations. (During execution t's allowed.)
> 8. Create undos.
Cheers, Sebastian
On 19/03/2012 at 05:42, xxxxxxxx wrote:
Hi Sebastian,
thanks for your note. Any suggestion for my last post?
Luther
On 21/03/2012 at 15:09, xxxxxxxx wrote:
The AnimateObject() function needs an animated object as far as I know.
That is , key framed in some fashion.
To run it safer, regarding Sebastians notes, do the AnimateObject() function
on a clone of the object (it is not inserted into the doc).
Lennart
