On 13/03/2012 at 10:48, xxxxxxxx wrote:
I got a problem working with Thinking Particles & Dynamics. If I apply the dynamic tag to a Particle Geometry object I got the dynamic behavior on the objects generated by the PG itself, but the particles don't follow them. In other words, the TP generation is used just to give birth to the objects, then the latter got dynamics while Thinking Particles follow the behavior determined by the TP nodes.
I need to access the dynamic objects, so is there a way to access the Particle Geometry structure via Python and navigate through the objects one by one? If not, is it possible to link the TP particles (position and alignment) to the dynamic objects generated by the Particle Geometry?
Riccardo
