On 12/03/2012 at 14:26, xxxxxxxx wrote:
hi,
i' am trying to create my first actual plugin. i have some minor experience with pyhton scripts and python xpresso nodes, so i am used to the SDK and the language itself. i am following the the python example project Py-RoundedTube and the description files of c4d.olight.
i understood basicly the description system , but nevertheless i am pretty much stuck now. i cannot init the values properly which i set up in my description files. i have tried to use different ids, removed description layout groups and more without any real success.
here is my project cropped to the relevant parts :
** Polylight.pyp**
import c4d import math import sys import os from c4d import plugins, utils, bitmaps, gui PLUGIN_ID = 1028340 class Opolylight(plugins.ObjectData) : def Init(self, op) : self.InitAttr(op, c4d.Vector, [c4d.LIGHT_COLOR]) self.InitAttr(op, float, [c4d.LIGHT_BRIGHTNESS]) self.InitAttr(op, int, [c4d.LIGHT_TYPE]) self.InitAttr(op, int, [c4d.EMITDIRECTION]) self.InitAttr(op, int, [c4d.SAMPLINGMODE]) self.InitAttr(op, int, [c4d.MAXIMUMSAMPLES]) self.InitAttr(op, float, [c4d.ACCURACY]) self.InitAttr(op, bool, [c4d.ACCURATECOLOR]) self.InitAttr(op, bool, [c4d.ISAREALIGHT]) self.InitAttr(op, bool, [c4d.SEENBYGI]) self.InitAttr(op, bool, [c4d.SEENBYBYCAMERA]) self.InitAttr(op, bool, [c4d.SEENBYBYREFLECTIONS]) self.InitAttr(op, bool, [c4d.SEENBYBYREFRACTIONS]) self.InitAttr(op, int, [c4d.DISPLAYMODE]) op[c4d.LIGHT_COLOR] = c4d.Vector(1.0,1.0,1.0) op[c4d.LIGHT_BRIGHTNESS] = 1.0 op[c4d.LIGHT_TYPE] = 1 op[c4d.EMITDIRECTION] = 2 op[c4d.SAMPLINGMODE] = 2 op[c4d.MAXIMUMSAMPLES] = 128 op[c4d.SAMPLINGMODE] = 0 op[c4d.ACCURACY] = 0.65 op[c4d.ACCURATECOLOR] = False op[c4d.ISAREALIGHT] = True op[c4d.SEENBYGI] = True op[c4d.SEENBYBYCAMERA] = True op[c4d.SEENBYBYREFLECTIONS] = True op[c4d.SEENBYBYREFRACTIONS] = True op[c4d.DISPLAYMODE] = 2 return True def Draw(self, op, type, bd, bh) : return c4d.DRAWRESULT_OK def GetVirtualObjects(self, op, hierarchyhelp) : dirty = op.CheckCache(hierarchyhelp) or op.IsDirty(c4d.DIRTY_DATA) if dirty is False: return op.GetCache(hierarchyhelp) return c4d.BaseObject(c4d.Ocube) if __name__ == "__main__": path, file = os.path.split(__file__) icon = bitmaps.BaseBitmap() icon.InitWith(os.path.join(path, "res", "polylight.tif")) plugins.RegisterObjectPlugin(id = PLUGIN_ID, str = "Polylight", g = Opolylight, description = "Opolylight", icon = icon, info = c4d.OBJECT_GENERATOR)
Opolylight.res (i know the layout is a bit heavy , but i suspected some formating errors here, so i formated it in this super safe way)
CONTAINER Opolylight { NAME Opolylight; INCLUDE Obase; HIDE ID_BASEOBJECT_USECOLOR; HIDE ID_BASEOBJECT_COLOR; GROUP GENERAL_GRP { DEFAULT 1; COLOR LIGHT_COLOR {OPEN;} REAL LIGHT_BRIGHTNESS { UNIT PERCENT; MIN 0; MAX 1000000.0; MINSLIDER 0.0; MAXSLIDER 1000.0; STEP 5; CUSTOMGUI REALSLIDER; } LONG LIGHT_TYPE { CYCLE { LIGHT_TYPE_DISC; LIGHT_TYPE_PLANE; -1; LIGHT_TYPE_CUBE; LIGHT_TYPE_CYLINDER; LIGHT_TYPE_SPHERE; -1; LIGHT_TYPE_OBJECT; } } LONG EMITDIRECTION { CYCLE { EMITDIRECTION_FRONT; EMITDIRECTION_BACK; EMITDIRECTION_BOTH; } } SEPARATOR { LINE; } LONG SAMPLINGMODE { CYCLE { SAMPLINGMODE_NORMAL; SAMPLINGMODE_OVERSAMPLING; SAMPLINGMODE_QMC; SAMPLINGMODE_PERPIXELQMC; } } LONG MAXIMUMSAMPLES { MIN 16; MAX 16384; } REAL ACCURACY { PARENTID MAXIMUMSAMPLES; UNIT PERCENT; MIN 0.0; MAX 100.0; } BOOL ACCURATECOLOR {} BOOL ISAREALIGHT {} SEPARATOR { LINE; } BOOL SEENBYGI {} BOOL SEENBYCAMERA {} BOOL SEENBYREFLECTIONS {} BOOL SEENBYREFRACTIONS {} SEPARATOR { LINE; } LONG DISPLAYMODE { CYCLE { DISPLAYMODE_ICON; DISPLAYMODE_ISOPARMS; DISPLAYMODE_FULL; } } } }
** Opolylight.h**
#ifndef _OPOLYLIGHT_H_ #define _OPOLYLIGHT_H_ // MaxID = 1107 enum { Opolylight = 10000 , GENERAL_GRP , LIGHT_COLOR = 1001, LIGHT_BRIGHTNESS = 1002 , LIGHT_TYPE = 1003 , LIGHT_TYPE_DISC = 0 , LIGHT_TYPE_PLANE = 1 , LIGHT_TYPE_CUBE = 2 , LIGHT_TYPE_CYLINDER = 3 , LIGHT_TYPE_SPHERE = 4 , LIGHT_TYPE_OBJECT = 5 , EMITDIRECTION = 1004 , EMITDIRECTION_FRONT = 0 , EMITDIRECTION_BACK = 1 , EMITDIRECTION_BOTH = 2 , SAMPLINGMODE = 1005 , SAMPLINGMODE_NORMAL = 0 , SAMPLINGMODE_OVERSAMPLING = 1 , SAMPLINGMODE_QMC = 2 , SAMPLINGMODE_PERPIXELQMC = 3 , MAXIMUMSAMPLES = 1006 , ACCURACY = 1007 , ACCURATECOLOR = 1008 , ISAREALIGHT = 1009 , SEENBYGI = 1010 , SEENBYCAMERA = 1011 , SEENBYREFLECTIONS = 1012 , SEENBYREFRACTIONS = 1013 , DISPLAYMODE = 1014 , DISPLAYMODE_ICON = 0 , DISPLAYMODE_ISOPARMS = 1 , DISPLAYMODE_FULL = 2 , }; #endif
and there is also a Opolylight.str file of course.
when i execute the plugin the following things happen :
cheers, ferdinand _ _
On 12/03/2012 at 14:31, xxxxxxxx wrote:
here are the files :
https://docs.google.com/file/d/0ByJvCHzEwMdlVUc2N2YzSEhTWU9nenZ2UmRlMUhGUQ/edit
On 12/03/2012 at 14:58, xxxxxxxx wrote:
Se if doing the init on the DataInstance helps. (What I do in an object plugin of mine.)
class Opolylight(plugins.ObjectData) : def Init(self, op) : data = op.GetDataInstance() data.SetVector(c4d.LIGHT_COLOR,c4d.Vector(1.0,1.0,1.0) data.SetFloat(c4d.LIGHT_BRIGHTNESS,1.0) data.SetLong(c4d.LIGHT_TYPE,1) etc… return True def Draw() def GetVirtualObjects()
Cheers Lennart
On 12/03/2012 at 20:08, xxxxxxxx wrote:
thank for your reply, the console still returns:
> AttributeError: 'module' object has no attribute 'SEENBYBYCAMERA'
for :
def Init(self, op) : data = op.GetDataInstance() data.SetVector(c4d.LIGHT_COLOR,c4d.Vector(1.0,1.0,1.0)) data.SetReal(c4d.LIGHT_BRIGHTNESS,1.0) data.SetLong(c4d.LIGHT_TYPE,1) data.SetLong(c4d.EMITDIRECTION,2) data.SetLong(c4d.SAMPLINGMODE,2) data.SetLong(c4d.MAXIMUMSAMPLES,128) data.SetReal(c4d.ACCURACY,0.65) data.SetBool(c4d.ACCURATECOLOR, True) data.SetBool(c4d.ISAREALIGHT, True) data.SetBool(c4d.SEENBYGI, True) data.SetBool(c4d.SEENBYBYCAMERA, True) data.SetBool(c4d.SEENBYBYREFLECTIONS, True) data.SetBool(c4d.SEENBYBYREFRACTIONS, True) data.SetLong(c4d.DISPLAYMODE,2) return True
gnahgnahgnah ...
edit : it is in this semi-working state like it is when i remove :
1-4 correct, 5-7 wrong, 8-9 correct, 10-11 wrong, 12 correct, 13-14 wrong ... oO
On 12/03/2012 at 20:27, xxxxxxxx wrote:
"SEENBYBYCAMERA" ?
On 12/03/2012 at 20:33, xxxxxxxx wrote:
not sure what you want to say ? SEENBYCAMERA like the boolean in the compositing tag.
On 12/03/2012 at 20:39, xxxxxxxx wrote:
seenBYBYcamera, I guess it easy to get "word blind". Check the spelling:)
On 12/03/2012 at 20:49, xxxxxxxx wrote:
weeh,
its far too late for me however, after correcting the typo the console returns :
_ AttributeError: 'module' object has no attribute 'SEENBYREFLECTIONS' _ _ _ the funny thing is, c4d.SEENBYREFLECTIONS is true and its checkbox is checked. if there is a god, its a cruel one
On 12/03/2012 at 21:52, xxxxxxxx wrote:
Perhaps you are having trouble because you changed your descriptions. But didn't delete your coffeesymbolcache file?
That one tends to burn everyone at least once.
On 13/03/2012 at 05:19, xxxxxxxx wrote:
To me,
looks spelt wrong "..BYBY.." but also as Scott mentioned, the coffesymbolcache file might need to be deleted for Cinema to update it.
On 13/03/2012 at 09:22, xxxxxxxx wrote:
that did the trick cannot express it in words how gratefull i am for your help and how angry i am, that neither the c++ sdk nor the python sdk mention this with a word (at least at their description sections).
On 13/03/2012 at 09:37, xxxxxxxx wrote:
The file is located here on a Windows OS:C:\YOUR username here\user\AppData\Roaming\MAXON\YOUR c4d version here\prefs\coffeesymbolcache
You didn't specify Mac or PC. Or what version you're using. There are a great many differences between R12 & R13. So please always provide that info in your posts.
BTW: I don't know if you know this or not. But the file link you posted says I need special permission from you to download it. That's not going to get you a lot of help either.
On 13/03/2012 at 09:54, xxxxxxxx wrote:
sorry about the google docs. but the problem is solved i found the file and it works, again thanks for your help
On 13/03/2012 at 10:14, xxxxxxxx wrote:
Lol.
That stupid cache file thing is sort of a rite of passage that all python plugin newbies have to go through. It's sort of like a fraternity hazing...Everyone has to go through it at least once to be in the club.
