On 11/03/2012 at 01:19, xxxxxxxx wrote:
All other Layer icons can be toggled (with effect) except for Solo
why does it need the added Button click simulation
import c4d from c4d import * def main() : doc = c4d.documents.GetActiveDocument() root = doc.GetLayerObjectRoot()#Gets the layer manager LayersList = root.GetChildren() toggled = 0 for layers in LayersList: #print layers.GetName() if layers.GetBit(c4d.BIT_ACTIVE) :# if the layer is selected layer_data = layers.GetLayerData(doc) layer_data['solo'] = not layer_data['solo'] layers.SetLayerData(doc,layer_data) toggled=1 c4d.EventAdd() if toggled == 0: gui.MessageDialog("Select a layer to use the script") return False CallButton(layers, 100004726) # why do we need this when other items in the layer list do not if __name__=='__main__': main()
ie. all the other icons can be toggled and function without a button click?
import c4d from c4d import gui def main() : #c4d.CallCommand(13957); # Clear console doc = c4d.documents.GetActiveDocument() root = doc.GetLayerObjectRoot()#Gets the layer manager LayersList = root.GetChildren() toggled = 0 for layers in LayersList: if layers.GetBit(c4d.BIT_ACTIVE) :# if the layer is selected layer_data = layers.GetLayerData(doc) layer_data['view'] = not layer_data['view'] layer_data['render'] = not layer_data['render'] layer_data['manager'] = not layer_data['manager'] layer_data['locked'] = not layer_data['locked'] layer_data['generators'] = not layer_data['generators'] layer_data['expressions'] = not layer_data['expressions'] layer_data['animation'] = not layer_data['animation'] layer_data['deformers'] = not layer_data['deformers'] layers.SetLayerData(doc,layer_data) toggled=1 c4d.EventAdd() if toggled == 0: gui.MessageDialog("Select a layer to use the script") return False if __name__=='__main__': main()
On 11/03/2012 at 07:10, xxxxxxxx wrote:
and to add to that not sure if its a bug
but layer_data['deformers'] = not layer_data['deformers'] isn't working
On 11/03/2012 at 11:04, xxxxxxxx wrote:
I haven't seen anyone from Maxon post here in about a week. They might be at trade shows or something. So I don't know if you're going to get a reply to this anytime soon.
This is my interpretation of how it works: In the C++ SDK it shows that Solo has it's own NBIT code to use to solo the object the layer is on. When the user physically clicks the solo icon in the LayerObject. It sends an NBIT message to the object the layer is on. And solos the object as expected. But if you change just the LayerObject's solo state with code, and not physically clicking on it. The ChangeNBit() message never gets sent to the object. So it doesn't do anything.
Here's a C++ example showing LayerObject & ChangeNBit()working together to solo the object:
GeListHead *list = NULL; list = doc->GetLayerObjectRoot(); //Get the root and store it in the GeListHead variable called "list" if(!list) return FALSE; LayerObject *layer = (LayerObject* )list->GetFirst(); //Get the first layer if(!layer) return TRUE; const LayerData *data = layer->GetLayerData(doc,FALSE); //Get the layer's container LayerData newdata(*data); //Adds a new custom entry into the layer's container newdata.solo = TRUE; //Set the SOLO option to on in memory doc->StartUndo(); doc->AddUndo(UNDOTYPE_CHANGE,layer); layer->SetLayerData(doc, newdata); //Execute the changes made to the layer //The object in the OM needs it's bit set to SOLO //The LayerObject alone will not make the object update by itself doc->AddUndo(UNDOTYPE_BITS,doc); doc->ChangeNBit(NBIT_SOLO_LAYER, NBITCONTROL_SET); //Executes the NBIT_SOLO_LAYER option doc->EndUndo(); EventAdd();
I think you're your CallButton(layers, 100004726) code fools C4D into sending the ChangeNBit() message to the object. That's why it works. When the Maxon guys get back they can maybe shed better light on how it works if I've got it wrong.
On 11/03/2012 at 11:13, xxxxxxxx wrote:
Thanks for your thoughts Scott.
More code - always useful.
Will try to get my hard around this.
