On 03/03/2012 at 17:28, xxxxxxxx wrote:
Hi all, I'm trying to storage the position of all particles of a group when were born. Here's my code: tp = doc.GetParticleSystem() TpGroupA = op[c4d.ID_USERDATA,1] cntGroupA = TpGroupA.NumParticles() PPGroupA = TpGroupA.GetParticles() PPGroupStart = c4d.Vector PPGroupStartPos = [] for i in xrange (cntGroupA) : if tp.IsBorn(i)==True: PPGroupStart = tp.Position(PPGroupA _) tp.SetPData(i,0,PPGroupStart) # I have created a Channels (vector) where storage the position PPGroupStartPos.append(tp.GetPData(i,0))
But it works only when I play the scene from the first frame... If I jump from a frame to another the Channel value became "None"
What's wrong in this code? There's another way retrive the born position of particle?
Luther
On 06/03/2012 at 17:35, xxxxxxxx wrote:
not sure hat is going wrong, but the setup looks quite compilacted. why don't you use just a python node with a TpParticle input port and plug a PPass node into it ? the *code *would be :
import c4d mycache = [] def main() : if tp.IsBorn(pid) : tp.SetPData(pid, 0, tp.Position(pid)) mycache.append(tp.Position(pid))
can't see a reason to do the iteration stuff yourself (ps : tp as the documents master particle system is predefined and pid is the name of my TpParticle input port)
On 09/03/2012 at 05:44, xxxxxxxx wrote:
Hi Little Devil, thank you so much for you reply. I'm a little bit confused, I think that I don't understand very well what do you suggest. I attach my c4d scene, so you can see what I really want to do: https://docs.google.com/open?id=0B4E_u8h_R81SSGdrX1BnZkdTRm1Nb0VLblM5VVZuUQ
Another thing, in a older your post I read that if I want to generate all particles at frame 0 I have to cache first my particle. Can you write me a little example of this code?
On 09/03/2012 at 13:37, xxxxxxxx wrote:
i think i am getting something wrong, it is very simple, i have attached an example.
http://www.2shared.com/file/mpgLW-_R/LineStartPGroup002.html
to your second question : can't see a reason for this, please explain what you want to achieve. basicly it would be the same. check if it is frame 0, check if particle id is related to a born particle and then do something with this id.
On 13/03/2012 at 06:02, xxxxxxxx wrote:
Hi Little Devil, sorry for the late responce... Thank you so much for you reply, now I have understand. For the second question, never mind... I was confused
