On 03/03/2012 at 12:21, xxxxxxxx wrote:
Trying to work out how to get all edges on a poly object selected when dropping into a Python Generator
i.e. nothing selected before dropping on to generator (so it becomes a child of the generator - with all edges selected)
tried all manner of things - put me out of my misery please
On 06/03/2012 at 03:40, xxxxxxxx wrote:
Anyone?
On 06/03/2012 at 08:22, xxxxxxxx wrote:
Here's one way to do it:
import c4d from c4d import utils def main() : obj = doc.SearchObject("Polygon")#The polygon object if obj.GetUp() is None: return False if obj.GetUp().GetName() == "Python Generator": obj.Edit() #Make the object active doc.SetMode(c4d.Medges) #Change to edges mode utils.SendModelingCommand(c4d.MCOMMAND_SELECTALL, list = [obj], mode = c4d.MODELINGCOMMANDMODE_EDGESELECTION, bc = c4d.BaseContainer(), doc = doc) c4d.EventAdd() #Update C4D if __name__=='__main__': main()
On 06/03/2012 at 13:08, xxxxxxxx wrote:
Hi Scott
I'm doing this from the generator itself but I think the edit and set mode code you've posted are the key just have to find a way to stop the poly objects from constantly selecting itself
appreciate feedback
atb
Paul
