On 26/02/2012 at 11:50, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12 Platform: Windows ; Language(s) : C++ ;
--------- Hey guys,
I'm having a hard time finding how to change the cursor's appearance within C++ dialog plugins. I can get the LMB state and store the desired cursor appearance type into a BaseContainer just fine. And when I use the LMB it does print the correct ID# for that cursor type. But I can't make the cursor's appearance change.
LONG myDialog::Message(const BaseContainer &msg, BaseContainer &result) { BaseContainer bc; //Used to hold the type of cursor to display BaseContainer state; //Used to hold the state of the LMB while (GetInputState(BFM_INPUT_MOUSE, BFM_INPUT_MOUSELEFT, state)) //While the LMB is held down { if(state.GetLong(BFM_INPUT_VALUE) == 0) break; //If the state value is 0. The LMB is no longer down..so exit the loop LONG x = state.GetLong(BFM_INPUT_X); //Get the cursor's X screen coordinates LONG y = state.GetLong(BFM_INPUT_Y); //Get the cursor's Y screen coordinates //GePrint(LongToString(x)); //GePrint(LongToString(y)); bc.SetLong(RESULT_CURSOR,MOUSE_POINT_HAND); //Store the cursor type into the container GePrint(LongToString(bc.GetLong(RESULT_CURSOR))); //Prints #19 when the LMB is pressed...Working good so far... if (bc.GetId()==MOUSE_POINT_HAND) return TRUE; //<---Wrong? // ...do more stuff } return GeDialog::Message(msg,result); }
When using the GetCursorInfo() method. They just use SetLong(). And for some reason it works. But since I'm using a dialog plugin. I can't use GetCursorInfo(). And using SetLong() isn't working for me. What am I missing?
On 26/02/2012 at 16:57, xxxxxxxx wrote:
Use GeShowMouse() to set the cursor type (from anywhere).
On 26/02/2012 at 17:29, xxxxxxxx wrote:
Thanks Robert.
