On 23/02/2012 at 08:13, xxxxxxxx wrote:
--------- Checked in R12 and R13. The following are the constants for which c4d.GetViewColor does not return Vector(0).
COLORBYTES_ACMYK COLORBYTES_AGRAY COLORBYTES_AGRAYf COLORBYTES_ARGB COLORBYTES_ARGBf COLORBYTES_CMYK COLORBYTES_GRAY COLORBYTES_GRAYf COLORBYTES_MAX COLORBYTES_RGB COLORBYTES_RGBf COLORMODE_ACMYK COLORMODE_AGRAY COLORMODE_AGRAYw COLORMODE_ALPHA COLORMODE_AMASK COLORMODE_ARGB COLORMODE_ARGBf COLORMODE_ARGBw COLORMODE_CMYK COLORMODE_GRAY COLORMODE_GRAYw COLORMODE_ILLEGAL COLORMODE_ILLEGALw COLORMODE_MASK COLORMODE_MASKf COLORMODE_MASKw COLORMODE_RGB COLORMODE_RGBf COLORMODE_RGBw COLORPROFILEINFO_COPYRIGHT COLORPROFILEINFO_DESCRIPTION COLORPROFILEINFO_MANUFACTURER COLORPROFILEINFO_MODEL COLORSPACETRANSFORMATION_LINEAR_TO_SRGB COLORSPACETRANSFORMATION_LINEAR_TO_VIEW COLORSPACETRANSFORMATION_NONE COLORSPACETRANSFORMATION_SRGB_TO_LINEAR COLORSPACETRANSFORMATION_SRGB_TO_VIEW COLORSYSTEM_HSV COLORSYSTEM_HSVTAB COLORSYSTEM_HSV_COLOR COLORSYSTEM_RANGE_255 COLORSYSTEM_RANGE_65535 COLORSYSTEM_RANGE_DEGREE COLORSYSTEM_RANGE_PERCENT COLORSYSTEM_RGB COLORSYSTEM_RGB_COLOR
The following are the constants for which it returns Vector(0). I don't see that much black in Cinema 4D, that's why it seems like a bug to me.
COLORMAPPING_BACKGROUND COLORMAPPING_BRIGHTMULTIPLIER COLORMAPPING_DARKMULTIPLIER COLORMAPPING_EXPONENTIAL COLORMAPPING_HSV COLORMODE_AGRAYf COLORMODE_GRAYf COLORMODE_ILLEGALf COLORMODE_MAXCOLOR COLORSHADER_BRIGHTNESS COLORSHADER_COLOR COLORSYSTEM_TABLE COLOR_3DTEXT COLOR_AM_ANIMDOT COLOR_AM_ANIMDOT_CHANGED COLOR_AM_ANIMDOT_MUTED COLOR_AM_BPDOT COLOR_B COLOR_BG COLOR_BGEDIT COLOR_BGFOCUS COLOR_BGGADGET COLOR_BGSELECTEDTEXT COLOR_BGTRISTATE COLOR_BG_DARK1 COLOR_BG_DARK2 COLOR_BG_GROUP1 COLOR_BG_GROUP2 COLOR_BG_GROUPBAR1 COLOR_BG_GROUPBAR2 COLOR_BG_MM_E_ACTIVE_LAYER COLOR_BG_MM_E_ACTIVE_TEXTURE COLOR_BG_MM_E_INACTIVE_LAYER COLOR_BG_MM_E_INACTIVE_TEXTURE COLOR_BG_MM_E_SELECTED_LAYER COLOR_BG_PALETTE COLOR_BG_TEXTUREVIEW COLOR_BORDER_ACTIVE_1 COLOR_BORDER_ACTIVE_3 COLOR_BORDER_ACTIVE_4 COLOR_BORDER_PALETTE COLOR_BUBBLE_BG COLOR_BUBBLE_BORDER COLOR_BUBBLE_FG COLOR_CONSOLE_BG COLOR_CONSOLE_TEXT COLOR_CONTENTBROWSER_BG_TEXT_ACT COLOR_CONTENTBROWSER_BG_TEXT_INACT COLOR_CONTENTBROWSER_FG_TEXT_ACT COLOR_CONTENTBROWSER_FG_TEXT_INACT COLOR_CONTENTBROWSER_NOTAVAILABLE COLOR_CONTENTBROWSER_TEXT COLOR_CTIMELINE_BG COLOR_CTIMELINE_BGOUTSIDE COLOR_CTIMELINE_BGPREVIEW COLOR_CTIMELINE_BREAKDOWN COLOR_CTIMELINE_CLIP COLOR_CTIMELINE_CLIPMASTER COLOR_CTIMELINE_CLIPTEXT COLOR_CTIMELINE_CLIPTEXTHL COLOR_CTIMELINE_CURRENTFRAME COLOR_CTIMELINE_CURSORINDICATOR COLOR_CTIMELINE_FCHIGHLIGHT COLOR_CTIMELINE_FCKEY COLOR_CTIMELINE_FCSELECTION COLOR_CTIMELINE_GENERAL COLOR_CTIMELINE_GREY COLOR_CTIMELINE_GRID COLOR_CTIMELINE_GRIDTEXT COLOR_CTIMELINE_GRIDTEXTSUB COLOR_CTIMELINE_HIGHLIGHT COLOR_CTIMELINE_HLECURVE COLOR_CTIMELINE_KEYSYMBOLS COLOR_CTIMELINE_MARKER COLOR_CTIMELINE_MARKERTEXT COLOR_CTIMELINE_MASTERGREY COLOR_CTIMELINE_POSITION COLOR_CTIMELINE_REGIONAREA COLOR_CTIMELINE_ROTATION COLOR_CTIMELINE_SCALE COLOR_CTIMELINE_SELECTION COLOR_CTIMELINE_SELECTION2 COLOR_CTIMELINE_SEQUENCE COLOR_CTIMELINE_SNAPSHOT COLOR_CTIMELINE_SPLINE COLOR_CTIMELINE_TANGENT COLOR_CTIMELINE_TANGENT2 COLOR_CTIMELINE_TEXTCOLOR COLOR_DBARBG1 COLOR_DBARBG2 COLOR_DBARBG3 COLOR_DBARFG1 COLOR_DBARFG2 COLOR_DEPRECATED_XOR COLOR_DUMMY_ COLOR_EDGEBL COLOR_EDGEDK COLOR_EDGELT COLOR_EDGEWH COLOR_EMBOSS_DK COLOR_EMBOSS_WH COLOR_FGSELECTEDTEXT COLOR_FG_MM_E_ACTIVE_LAYER COLOR_FG_MM_E_ACTIVE_TEXTURE COLOR_FG_MM_E_INACTIVE_LAYER COLOR_FG_MM_E_INACTIVE_TEXTURE COLOR_FG_MM_E_SELECTED_LAYER COLOR_G COLOR_ICONS_BG_ACTIVE COLOR_MATERIALMANAGER_BG COLOR_MATERIALMANAGER_SELECTED COLOR_MATERIALMANAGER_TEXT COLOR_MATERIALMANAGER_TEXT_SELECTED COLOR_MENU_BG COLOR_MENU_BG_BORDER COLOR_MENU_BG_ICON COLOR_MENU_BG_SELECTED COLOR_MENU_BORDER_DK COLOR_MENU_BORDER_WH COLOR_MENU_TEXT COLOR_MENU_TEXT_DISABLED COLOR_MENU_TEXT_SELECTED COLOR_PAINTER_SELECTED COLOR_PAINTER_TREE COLOR_PALETTE_SEPARATOR COLOR_PALETTE_TEXT COLOR_PALETTE_TEXT_DISABLED COLOR_PALETTE_TEXT_SELECTED COLOR_POWERBG COLOR_POWERBGDRAG COLOR_POWEREDGE COLOR_POWERFRAME COLOR_POWERFRAMEDRAG COLOR_POWERFRAMEMARKER COLOR_POWERHANDLEDRAG COLOR_POWERKEYP COLOR_POWERKEYR COLOR_POWERKEYS COLOR_POWERKEYSELECTED COLOR_POWERKEYUNSELECTED COLOR_POWERLOOP COLOR_POWERSELECTED COLOR_POWERSLIDEBG COLOR_POWERSLIDEHANDLES COLOR_POWERSOUND COLOR_PROGRESSBAR COLOR_PV_ASAFE COLOR_PV_BUCKET COLOR_PV_CACHE COLOR_PV_COMPARE COLOR_PV_FPS COLOR_PV_FULLBG COLOR_PV_FULLBOR COLOR_PV_FULLELE COLOR_PV_FULLTXT COLOR_PV_HDHIGH COLOR_PV_HDLOW COLOR_PV_HDMED COLOR_PV_HISTO COLOR_PV_HISTOFILTER COLOR_PV_NAVIAREA COLOR_PV_NOTALL COLOR_PV_TEXT COLOR_PV_TSAFE COLOR_QUICKBAR_BG COLOR_QUICKBAR_BG2 COLOR_QUICKBAR_TEXT COLOR_QUICKBAR_TEXT2 COLOR_QUICKTAB_BG_ACTIVE COLOR_QUICKTAB_BG_ACTIVE_ALTERNATE1 COLOR_QUICKTAB_BG_INACTIVE COLOR_QUICKTAB_BORDER COLOR_QUICKTAB_TEXT_ACTIVE COLOR_QUICKTAB_TEXT_INACTIVE COLOR_R COLOR_RM_ERROR COLOR_RM_FINISHED COLOR_RM_PROG COLOR_RM_QUEUE COLOR_RM_STOP COLOR_SB_BG1 COLOR_SB_BG2 COLOR_SB_LAYER_BORDER COLOR_SB_TEXT COLOR_SB_TEXTHG1 COLOR_SB_TEXTHG2 COLOR_SB_TEXT_ACTIVE1 COLOR_SB_TEXT_ACTIVE2 COLOR_SB_TEXT_BORDER COLOR_SB_TEXT_FOLDER_MAIN COLOR_SB_TEXT_FOLDER_SUB COLOR_SB_TREE1 COLOR_SB_TREE2 COLOR_SPREADSHEET_BG COLOR_SPREADSHEET_EDITBG COLOR_SPREADSHEET_EDITTEXT COLOR_SPREADSHEET_SELECTED COLOR_SPREADSHEET_TEXT COLOR_SYNTAX_CLASS COLOR_SYNTAX_COFFEE COLOR_SYNTAX_COMMENT COLOR_SYNTAX_COMMENTWRONG COLOR_SYNTAX_CONSTANT COLOR_SYNTAX_FUNCTION COLOR_SYNTAX_INCLUDE COLOR_SYNTAX_MEMBER COLOR_SYNTAX_STRING COLOR_TEXT COLOR_TEXTFOCUS COLOR_TEXT_BUTTON COLOR_TEXT_BUTTON_DISABLED COLOR_TEXT_COMBO COLOR_TEXT_COMBO_DISABLED COLOR_TEXT_DISABLED COLOR_TEXT_EDIT COLOR_TEXT_EDIT_DISABLED COLOR_TEXT_MENU COLOR_TEXT_MENU_DISABLED COLOR_TEXT_SELECTED COLOR_TEXT_SELECTED_DARK COLOR_TEXT_TAB COLOR_TEXT_TAB_ACTIVE COLOR_TEXT_TAB_DISABLED COLOR_TRACK_S COLOR_TRACK_X COLOR_TRACK_Y COLOR_TRACK_Z COLOR_TRANS COLOR_XOR EX_COLOR_BROWSER_LINES_SELECTED EX_COLOR_CTIMELINE_COLOR EX_COLOR_CTIMELINE_MASTER EX_COLOR_CTIMELINE_MASTERIDENTICAL EX_COLOR_CTIMELINE_PLA EX_COLOR_FCURVE_BG EX_COLOR_FCURVE_GRAY1 EX_COLOR_FCURVE_GRAY2 EX_COLOR_FCURVE_GRAY3 EX_COLOR_FCURVE_LINES EX_COLOR_FCURVE_LLTGRAY EX_COLOR_FCURVE_MAINGRID EX_COLOR_FCURVE_POINTSELECTED EX_COLOR_FCURVE_SUBGRID EX_COLOR_FCURVE_TEXT EX_COLOR_OBJECTMANAGER_ACTIVECAMERA EX_COLOR_OBJECTMANAGER_BG EX_COLOR_OBJECTMANAGER_INACTIVECAMERA EX_COLOR_OBJECTMANAGER_SELECTEDTAG EX_COLOR_OBJECTMANAGER_TEXT EX_COLOR_OBJECTMANAGER_TEXT_ACTIVE EX_COLOR_OBJECTMANAGER_TEXT_ACTIVE2 EX_COLOR_OBJECTMANAGER_TEXT_ACTIVE3 EX_COLOR_OBJECTMANAGER_TREE EX_COLOR_TIMELINE EX_COLOR_TIMELINESCROLLER_CURRENT EX_COLOR_TIMELINESCROLLER_MINMAX EX_COLOR_TIMELINE_BG EX_COLOR_TIMELINE_BG_DARK EX_COLOR_TIMELINE_LAYER0 EX_COLOR_TIMELINE_LAYER1 EX_COLOR_TIMELINE_LAYER2 EX_COLOR_TIMELINE_LAYER3 EX_COLOR_TIMELINE_LAYER4 EX_COLOR_TIMELINE_LAYER5 EX_COLOR_TIMELINE_LAYER6 EX_COLOR_TIMELINE_LAYER7 EX_COLOR_TIMELINE_LINES EX_COLOR_TIMELINE_LINES_SEL EX_COLOR_TIMELINE_LINES_SEPARATOR1 EX_COLOR_TIMELINE_LINES_SEPARATOR2 EX_COLOR_TIMELINE_LOOP EX_COLOR_TIMELINE_SELECTION EX_COLOR_TIMELINE_TEXT EX_COLOR_TIMELINE_TEXT_SELECTED EX_COLOR_TIMELINE_TEXT_SELECTED2 EX_COLOR_TIMELINE_TICKS1 EX_COLOR_TIMELINE_TICKS2 EX_COLOR_TIMELINE_TREE
There are also some third-party constants (that don't start with EX_COLOR or COLOR) for which c4d.GetViewColor does not return Vector(0) and some, where it does.
This is the code I used to figure out all constants.
import c4d mode = "good" # or "bad" if mode == "bad": def compare(x) : return x == c4d.Vector(0) elif mode == "good": def compare(x) : return x != c4d.Vector(0) for e in dir(c4d) : if e.startswith("COLOR") or e.startswith("EX_COLOR") : v = getattr(c4d, e, None) if v is not None: v = c4d.GetViewColor(v) if compare(v) : print e
Also, c4d.SetViewColor doesn't seem to work, too.
PS: @Maxon support: There are many bug-reports that are not replied, something like "Checked", "On our list!" or "Just fixed this issue" would be nice.
On 24/02/2012 at 06:33, xxxxxxxx wrote:
The constants for GetViewColor start with VIEWCOLOR_ not COLOR_. This note will be added to the docs. Btw, constants which start with EX_ are outdated and will not work. //closed
On 11/12/2012 at 01:11, xxxxxxxx wrote:
Is it possible to get the color value of the constant colors? I want to use the "General - Text"-Color in a treeview
On 11/12/2012 at 01:16, xxxxxxxx wrote:
Nevermind just found the GetColorRGB. And sorry didn't realize that this is located in the bug reports.
