Editing Material Gradients in R13
On 21/02/2012 at 11:55, xxxxxxxx wrote:
I've managed to convert most of my materials C++ code to python. But I'm having trouble with two things.
1.- I can't figure out how to write the SetData() function in python
2.- I can't figure out how to change the gradient's interpolation mode
#2000 = 2D-U
#2001 = 2D-V
#2002 = 2D-Diagonal
#2003 = 2D-Radial
#2004 = 2D-Circular
#2005 = 2D-Box
#2006 = 2D-Star
#2007 = 2D-FourCorner
#2008 = 3D-Linear
#2009 = 3D-Cylindrical
#2010 = 3D-Spherical
from c4d import gui
from c4d.modules import render
def main() :
  mat = doc.GetFirstMaterial()
  color = c4d.DescLevel(c4d.MATERIAL_COLOR_COLOR, c4d.DTYPE_COLOR)#The material's color channel
  shdr = mat[c4d.MATERIAL_COLOR_SHADER]  #The shader inside the "texture" option
  shdr[c4d.SLA_GRADIENT_TYPE]= 2000      #The "Type" option
  shdr[c4d.SLA_GRADIENT_CYCLE] = True    #The "Cycle" option
  shdr[c4d.SLA_GRADIENT_TURBULENCE]=0    #The "Turbulence" option
  shdr[c4d.SLA_GRADIENT_SPACE]= 2021     #The "Space" option
  grad = shdr[c4d.SLA_GRADIENT_GRADIENT] #The gradient GUI
  count = grad.GetKnotCount()            #The number of gradient knots
  k1 = grad.GetKnot(0)                   #Gets the first knot
  k2 = grad.GetKnot(1)                   #Gets the second knot
  k1['pos'] = 0.1                        #Changes the first knot's position in memory only
  k2['pos'] = 0.8                        #Changes the second knot's position in memory only
  k1['col'] = c4d.Vector(0.5, 0.1, 0.0)  #Changes the first knot's color in memory only
  k2['col'] = c4d.Vector(1.0 , 1.0, 1.0) #Changes the second knot's color in memory only
  #grad.SetKnot(0,k1)<-------Crashes!!!
  #grad[c4d.GRADIENT_INTERPOLATION]<----Wrong!!...How do you change this option?
  mat.Message(c4d.MSG_UPDATE )
  mat.Update( True, True )
if __name__=='__main__':
Can anyone shed a light on these two things?
On 22/02/2012 at 01:27, xxxxxxxx wrote:
It's only possible to get / set the gradient data with GetData() and SetData(). So to retrieve the gradient interpolation we have to call:
gradient.GetData(c4d.GRADIENT_INTERPOLATION)
Which is c4d.GRADIENT_INTERPOLATION_SMOOTHKNOT by default (see customgui_gradient.h).
Also SLA_GRADIENT_TYPE and SLA_GRADIENT_SPACE enums are defined in xs**gradient.res (** is la, don't know why this is replaced).
On 22/02/2012 at 08:22, xxxxxxxx wrote:
Hi Yannick,
Something strange is going on.
I cannot change the interpolation option using your code either:
from c4d import gui
def main() :
  grad.SetData(c4d.GRADIENT_INTERPOLATION, c4d.GRADIENT_INTERPOLATION_SMOOTHKNOT)#<---Does Not work!!!
  print grad.GetData(c4d.GRADIENT_INTERPOLATION) #<---Always results in 2..It never changes!!!
I even tried the C++ way too:
grad.SetData(c4d.GRADIENT_INTERPOLATION, c4d.GRADIENTSUBCHANNEL_INTERPOLATION_SMOOTHKNOT)
And what about SetKnot()?
I cannot get that function to work. Even when I use it in it's most basic form:
-grad.SetKnot(0,['pos'] = 1.5)
-grad.SetKnot(0,pos = 1.5)
-etc...
I've tried a bunch of different things. But I cannot figure out the proper way to write this function either.
GRADIENT_INTERPOLATION data value is GRADIENT_INTERPOLATION_SMOOTHKNOT by default which value is 2 so this is normal :slightly_smiling_face:.
Try to set the gradient interpolation to GRADIENT_INTERPOLATION_LINEARKNOT which value is 3 and you'll see that it changes.
-etc...
I contacted the developers on this issue.
On 22/02/2012 at 13:47, xxxxxxxx wrote:
Yes.This will change it..... But in memory only:
If I change that attribute by hand to something else. The attribute itself does not change. And I'm already using C4D.Event() and c4d.MSG_UPDATE in my code. Making this useless until I know how to actually execute the changes that are stored in memory.
Being able to use the SetKnots() is actually a lot more important to me.
Thank you for taking it to the developers. And as always...Thanks for your efforts.
On 23/02/2012 at 02:09, xxxxxxxx wrote:
To edit a Gradient data (knots, interpolation, mode etc.) it needs to be reassigned. So your code would be:
grad = shdr[c4d.SLA_GRADIENT_GRADIENT] # Get the existing gradient data
grad.FlushKnots()
grad.InsertKnot(col=c4d.Vector(0.5, 0.1, 0.0), pos=0.1)
grad.InsertKnot(col=c4d.Vector(1.0 , 1.0, 1.0), pos=0.8)
shdr[c4d.SLA_GRADIENT_GRADIENT] = grad # Assign the edited gradient data so it's updated by C4D
On 23/02/2012 at 09:02, xxxxxxxx wrote:
Ahhaaaa!!!
shdr[c4d.SLA_GRADIENT_GRADIENT] = grad <--That's the sucker I was looking for. :thumbsup:
Now I can get everything to update properly.
Here is a full working example in case anyone needs it:
def main() :
  # First we get the material we want to work with
  mat = doc.GetFirstMaterial()           #Gets the first material in the materials manager
  # Now lets grab the gradient(also known as "Xlsagradient") that is already there in the color channel
  # We are not creating that gradient with code in this example..So it needs to be there already
  shdr[c4d.SLA_GRADIENT_TYPE]= 2000      #The "Type" option...ID's are found in the xlsagradient.h file
  shdr[c4d.SLA_GRADIENT_SPACE]= 2021     #The "Space" option...ID's are found in the xlsagradient.h file
  # Now lets drill into the gradient shader to control the knots, interpolation, and color bar
  grad = shdr[c4d.SLA_GRADIENT_GRADIENT] #Get the gradient GUI and assign it to a variable
  grad.FlushKnots()                      #Delete all existing knots
  k1 = grad.InsertKnot(col=c4d.Vector(0.5, 0.1, 0.0), pos=0.0,index = 0)  #Creates the first knot
  k2 = grad.InsertKnot(col=c4d.Vector(1.0 , 1.0, 1.0), pos=1.0,index= 1)  #Creates the second knot
  k1 = grad.GetKnot(k1)  #Get the first knot so we can read it's dictionary values
  k1pos = k1['pos']      #The position of the knot from the dict value 'pos'
  k1col = k1['col']      #The color of the knot from the dict value 'col'
  k2 = grad.GetKnot(k2)  #Get the second knot so we can read it's dictionary values
  k2pos = k2['pos']      #The position of the knot from the dict value 'pos'
  k2col = k2['col']      #The color of the knot from the dict value 'col'
  k3 = grad.InsertKnot(col=k1col+k2col/2, pos=k1pos+k2pos/2) #Create a new knot using the other knot's values
# Now lets change the position of the first knot's handle(diamond shape attribute) to this new value
  k1pos = 0.3
  grad.SetKnot(index=0,pos=k1pos)        #Set the handle to this new value
  grad.SetData(c4d.GRADIENT_INTERPOLATION, c4d.GRADIENT_INTERPOLATION_CUBICKNOT) #Change the interpolation
  shdr[c4d.SLA_GRADIENT_GRADIENT] = grad #Update the gradient data we changed
  mat.Message(c4d.MSG_UPDATE )           #Update the material changes
  mat.Update( True, True )               #Update the material's icon image
  c4d.EventAdd()                         #Update C4D so things update quickly
Thanks so much Yannick.:beer:
ScottA
On 27/04/2016 at 09:04, xxxxxxxx wrote:
Thanks a lot guys !!!!!!!!!!!!!!!!!!!!!!
