Threading with Python
On 12/02/2012 at 10:39, xxxxxxxx wrote:
I'm trying to figure out how to use threading for scripts. And having a hard time of it.
Here's my list of what I want to accomplish with threading:
1. Create a thread to run some code in it that is taxing(looping) on my system
2. Have the ability to stop the process with the ESC key by the user
3. Have this all done Asynchronously(Not sure if this is possible with scripts)Here's a code example to get things started:
import c4d from c4d import threading class MyThread(threading.C4DThread) : #Something to run and tax the system def myThreadedFunction(self) : for i in xrange(0,2000) : mt = c4d.threading.GeIsMainThread() #Test if the main thread is running print mt tId = c4d.threading.GeGetCurrentThreadId()#Get the threads ID print tId c4d.StatusSetText(i) c4d.StatusClear() def main() : thread = MyThread() thread.Start(c4d.THREADMODE_ASYNC, c4d.THREADPRIORITY_NORMAL) thread.myThreadedFunction() if __name__=='__main__': main()
This example has some problems.
-It returns "true" meaning that it's running in the main thread...Which is bad. I want another thread to be running instead.
-And I don't know how to add the ESC key to stop it from running.-ScottA
On 12/02/2012 at 11:17, xxxxxxxx wrote:
It is running in the current thread because you are calling it from the current thread.
(Line 19, last line in main())
The correct version of your could would be:import c4d import time class MyThread(c4d.threading.C4DThread) : def Main(self) : for i in xrange(0, 5) : if self.TestBreak() : print "Canceled thread-execution." return c4d.StatusSetText("Running since %d seconds." % i) time.sleep(1) c4d.StatusClear() def TestDBreak(self) : bc = c4d.BaseContainer() c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD, c4d.KEY_ESC, bc) # how to proceed? thread = MyThread() thread.Start()
But unfortunately I don't know how to proceed after GetInputState is called. Also, it always returns False in the Thread but does return True in the Main-thread.
@Official Support: Is this as supposed or is it a bug? The container isn't filled in another thread, only in the main-thread.
-Niklas
On 12/02/2012 at 12:22, xxxxxxxx wrote:
Originally posted by xxxxxxxx
[...]But unfortunately I don't know how to proceed after GetInputState is called. Also, it always returns False in the Thread but does return True in the Main-thread.@Official Support: Is this as supposed or is it a bug? The container isn't filled in another thread, only in the main-thread.Cheers,-Niklas
Have a look at the SDK docs ("Important threading information"). There are several things that are only allowed in the main thread - esp. GUI functionality (and therefore keyboard input), as the OS wouldn't support it otherwise.
Best regards,
Wilfried Behne
On 12/02/2012 at 12:55, xxxxxxxx wrote:
Can we terminate something that's running in a thread another way?
For example:Can we use a timer or something similar to stop running a script that's looping for too long?
I tried editing the example Nux posted to do that.
But even though I think I stopped the thread properly. It didn't stop processing the script.-ScottA
Can we terminate something that's running in a thread another way?For example:Can we use a timer or something similar to stop running a script that's looping for too long? I tried editing the example Nux posted to do that.But even though I think I stopped the thread properly. It didn't stop processing the script.-ScottA
Please have a look at the C4DThread methods described in the SDK docs (e.g. End(), TestBreak(), etc.).
Best regards,
Wilfried Behne
On 12/02/2012 at 19:10, xxxxxxxx wrote:
I've been trying to understand this. But it's not making sense.
If I end a thread using End(). It does not terminate the script code from running. It looks like all that does is acts like a switch to toggle the TestBreak() function from False- to- True:import c4d class MyThread(c4d.threading.C4DThread) : def Main(self) : i=0 while i<20: print i if self.TestBreak() : print "Thread Stopped" #TestBreak is a Boolean "False" value until triggered "True" when the thread is stopped if i>15: print "Stop" self.End(wait=True) #Triggers the thread to stop #return #Use this to stop the script from running any further i=i+1 thread = MyThread() thread.Start()
The only way I can see of using threads to terminate a script is by using it to control a return.
Is this correct?Here's something else that's strange to me.
Why does this code only return the numbers between 3001-3999?
Why doesn't it print the numbers 0 - 4000?import c4d class MyThread(c4d.threading.C4DThread) : def Main(self) : for i in xrange(0, 4000) : #Only returns the numbers 3001-3999!? print i thread = MyThread() thread.Start()
Why it the threading forcing the print function to only return a thousand numbers?
I've been trying to understand this. But it's not making sense.If I end a thread using End() [...]
The main thread does:
- interaction with the GUI (drawing, keyboard input, etc.)
- Spawns treads (by calling the Start() method)
- Tells the spawned threads that they should stop (by calling the End() method for the spawned threads)The spawned tread:
- checks via TestBreak(), if it should stop
- terminates by returning from its Main() methodBest regards,
Wilfried Behne
On 13/02/2012 at 04:41, xxxxxxxx wrote:
@wbeh: But how would I then implement reactin on user-input in a thread? The documentation does even point out that you can.
_<_dt id="c4dthread.testdbreak"_>_ `>Originally posted by xxxxxxxx
C4DThread.TestDBreak`( self )
Override this to add user breaks such as pressing ESC. This function is called by
TestBreak()
_="field-"=""> Return type:| bool
Returns:| True if processing should be terminated, otherwise <_<_t_>_ng>False**.@ScottA: You must exit the thread yourself.
def Main(self) : for ... : if self.TestBreak() : print "Quitting thread." break # or return, or whatever to quit the loop and / or the function
-Niklas
@wbeh: But how would I then implement reactin on user-input in a thread? The documentation does even point out that you [...]
Again: You DON'T do any GUI interaction in a spawned thread. In the spawned thread you either work, react to TestBreak() or you leave the thread because your work is done.
What you can do when overriding TestDBreak is something like this:
// Break function for the thread. A break will be signalled if the thread was requested to
// stop or if the current task takes too much time.
// Function result: -
Bool BackgroundThread::TestDBreak( void )
if ( please_suspend ) // stop it?
return( TRUE );if ( in_action ) // currently doing something?
LONG current;
LONG duration;
current = GeGetTimer(); // this is the time when the current action started
duration = current - action_start;
if ( duration > 1000 )
time_out = FALSE;
}if (( duration / 1000 ) > MySettings::GetUserSelectableTimeout())
time_out = TRUE;
return( TRUE );
return( FALSE );
}Best regards,
Wilfried Behne
On 13/02/2012 at 08:39, xxxxxxxx wrote:
Thanks a lot guys.
I now understand that threads don't stop running scripts. But they can be used as tests to determine when to execute a return, which in turn will stop the running script.But what's up with the strange returns I get when using a for loop inside a thread?
Why do I only get a thousand numbers from my print statement?
I don't understand why that's happening when I run a for loop inside of a thread class?Here's another version that also only prints out a thousand numbers:
import c4d class MyThread(c4d.threading.C4DThread) : def Main(self) : for i in xrange(0, 4000) : self.End() self.TestBreak() if self.TestBreak() : print i thread = MyThread() thread.Start()
I don't understand why that's happening when I run a for loop inside of a thread class?The console has a buffer of one thousand lines. This is why you only get the latest thousand numbers.
On 13/02/2012 at 10:47, xxxxxxxx wrote:
Not sure if I understand what that means Yannick.
The "for" loop generates print results starting from 0+ when used in the "main" thread.
But only 1000 values when used inside of a custom thread.
You say this is due to a console buffer limit. But I don't get the connection there.I guess it really doesn't matter if I understand how the console buffer works.
I just need to know if my loops will still work the same way in threads (starting from zero+) as they work in the main thread.
Should I just take it on faith that they work the same. Even though I can't use the print function to see the entire output values?-ScottA
On 13/02/2012 at 11:20, xxxxxxxx wrote:
@Scott:
Imagine you have printed exactly 1000 lines to the console.
for i in xrange(1000) : print "Current:", i
If you now print another one, the first line, which contains the string Current: 0, will be erased.
Next, why are you calling C4DThread.End() within the loop? It is intended to be used outside of the thread to notify you, while looping in the main, the thread should now exit.
import c4d import time class MyThread(c4d.threading.C4DThread) : def Main(self) : for i in xrange(100) : if self.TestBreak() : print "MyThread.TestBreak() returned True, leaving the loop.." break print "Current:", i time.sleep(1/25.) def main() : thread = MyThread() thread.Start() time.sleep(1) thread.End() main()
As expected, this code runs until frame 25 (maybe 24 or 26, that depends on the machine) and then exits because we told it to exit after we've waited for a second.
Current: 0 Current: 1 Current: 2 Current: 3 Current: 4 Current: 5 Current: 6 Current: 7 Current: 8 Current: 9 Current: 10 Current: 11 Current: 12 Current: 13 Current: 14 Current: 15 Current: 16 Current: 17 Current: 18 Current: 19 Current: 20 Current: 21 Current: 22 Current: 23 Current: 24 Current: 25 MyThread.TestBreak() returned True, leaving the loop..
-Niklas
PS: What is up with my posts? I see scrollbars for it, never seen that before here..
On 13/02/2012 at 12:26, xxxxxxxx wrote:
Thanks for correcting me on that Nux.
Now I see why it was returning only the last 1000 numbers the way I was using it.Thanks to everyone for the great information in this thread... um...about threading.
Lots of good information in here.-ScottA
On 05/10/2017 at 21:44, xxxxxxxx wrote:
Check this one...Python thread basics
