On 10/02/2012 at 01:55, xxxxxxxx wrote:
--------- Hi, I am trying to get the pointscount of a polygonselection, which is stored in a polygonselectionTag. I tried
int points = op->GetTagDataCount(Tpoint);
before that i set the selection tag as active. All i get is the full amount of points from the Object. If i use a Cube it gives me 8 Points becuase a Cube got only 8. But the right value would be 4 if i've selected only one face. I need the pointcount to set a weightmap. If I am not mistaken i can make weightmap for my joints with the function "setWeightMap(Joint_index,map(float number),Pointcount) So the Question is do I have to use this way:
BaseDocument *doc = GetActiveDocument(); BaseObject *obj = doc->GetActiveObject(); PolygonObject *pobj = ToPoly(obj); AutoAlloc<SelectionTag> st(Tpolygonselection); if(newpolytag->GetType() &Tpolygonselection) { BaseSelect *select= static_cast<SelectionTag*>(newpolytag)->GetBaseSelect(); sel->CopyTo(select); } LONG count = pobj->GetPolygonCount();
To work my way through the number of points? Or is there an easier way, to get the points amount of the selection?
On 10/02/2012 at 04:32, xxxxxxxx wrote:
You need to convert your polygon selection into a point selection. Take a look at the SelectionChanger class.
On 10/02/2012 at 04:59, xxxxxxxx wrote:
hm ok since this only converts it into a pointselection. So I've to convert it afterwards into a pointObject. And then get the pointscount();
The other thing what make me wonder is how to set the weight map on those points in the pointselection area.
On 10/02/2012 at 05:52, xxxxxxxx wrote:
Once you've got the point selection
I think you can do the rest by
count = obj.GetPointS().GetCount()
On 10/02/2012 at 05:58, xxxxxxxx wrote:
Originally posted by xxxxxxxx hm ok since this only converts it into a pointselection. So I've to convert it afterwards into a pointObject. And then get the pointscount();
Once you have a BaseSelect returned by the SelectionChanger, just do BaseSelect::GetCount(). To access those points, of course you will need to get the object's points array. You can use:
Vector *padr = ToPoint(yourobject)->GetPointR();
The SDK docs for BaseSelect shows you how to get the selected points (look for BaseSelect::IsSelected())
Steve
