On 09/02/2012 at 06:56, xxxxxxxx wrote:
User Information: Cinema 4D Version: R13 Platform: Windows ; Language(s) : C++ ;
--------- I'm trying to get BaseObject(s) from Linkbox of plugin.
Using ResEdit plugin I've made a dialog which has two linkboxes so that I can drag two different objects into them to make a plugin that enables to swap their positions.
For example,
ID of each linkbox : IDC_OBJECT1, IDC_OBJECT2
Members: BaseObject* op1, op2; LinkBoxGui* linkbox1; LinkBoxGui* linkbox2;
I tried as following: linkbox1 = (LinkBoxGui* )FindCustomGui(IDC_OBJECT1, CUSTOMGUI_LINKBOX);
However I don't know how to get the BaseObject from linkbox. op1 = ....?
Or is there another way to do this?
Thank you in advance.
On 09/02/2012 at 08:15, xxxxxxxx wrote:
You can call LinkBoxGui::GetLink() and cast the returned object to a BaseObject:
BaseObject* op = (BaseObject* )linkbox->GetLink(GetActiveDocument(), Xlayer);
This line is from the LayerShaderBrowser example.
Regards,
On 09/02/2012 at 18:04, xxxxxxxx wrote:
Yannick Puech, thank you for your answer.
I tried as you guided, but I have still problems.
In my opinion, the problems is caused by the second parameter of GetLink function, Xlayer, corresponds only for shader instances.
C++ HTML documentation reads:
However, I don't know what I have to put the second parameter, LONG instance, to get the BaseObject instance.
My dialogbox, header files and cpp file look like this:
Dialogbox: http://blog.naver.com/gchoi_acts/130130991792
//================================== // c4d_symbols.h //================================== enum { // Dialog definitions of IDD_SWAP_POSITION start here IDD_SWAP_POSITION, // ID of the Dialog Box IDC_OBJECT1, // ID of the first linkbox IDC_OBJECT2, // ID of the second linkbox // Dialog definitions of IDD_SWAP_POSITION end here
// End of symbol definition _DUMMY_ELEMENT_ };
//================================== // SwapPosition.h //================================== #include "c4d_gui.h" class SwapPosition : public GeDialog { public: SwapPosition (); virtual ~SwapPosition ();
virtual Bool CreateLayout(void); virtual Bool InitValues(void); virtual Bool Command(LONG id, const BaseContainer &msg); virtual LONG Message(const BaseContainer& msg, BaseContainer& result); void UpdateAll(Bool msg); void \*lastselected;
private: LONG lastdirty; BaseDocument* doc; BaseObject* op1, op2; LinkBoxGui* linkbox1, linkbox2; };
//================================== // SwapPosition.cpp //================================== #include "c4d.h" #include "c4d_symbols.h" #include "SwapPosition.h" ... Bool SwapPosition ::Command(LONG id, const BaseContainer &msg) { //## GET USER ENTERED DATA: switch (id) { case IDC_OK: linkbox1 = (LinkBoxGui* )FindCustomGui(IDC_OBJECT1, CUSTOMGUI_LINKBOX); if(!linkbox1) return FALSE; op1 = (BaseObject* )linkbox1->GetLink(GetActiveDocument(), Xlayer);
linkbox2 = (LinkBoxGui\* )FindCustomGui(IDC_OBJECT2, CUSTOMGUI_LINKBOX); if(!linkbox2) return FALSE; op2 = (BaseObject\* )linkbox2->GetLink(GetActiveDocument(), Xlayer); GePrint("Object Name : " + op1->GetName()); // <======= ERROR OCCURRED GePrint("Object Name : " + op2->GetName()); // <======= ERROR OCCURRED break; case IDC_CANCEL: break; default: break; } return TRUE;
================================ Thank you for your answer in adavance.
Best regards, gchoi
On 09/02/2012 at 18:48, xxxxxxxx wrote:
Try Obase. If that works. There are other types listed under: OObjectType Just in case you need to use them some day.
On 09/02/2012 at 19:57, xxxxxxxx wrote:
Thank you for your reply, ScottA.
I've just solved my problem by omitting the second parameter of the membert function, GetLink and the code looks like this:
//=================================================== // SwapPosition.cpp //===================================================
Bool SwapPosition ::Command(LONG id, const BaseContainer &msg) { //## GET USER ENTERED DATA: switch (id) { case IDC_OK: linkbox1 = (LinkBoxGui* )FindCustomGui(IDC_OBJECT1, CUSTOMGUI_LINKBOX); if(!linkbox1) return FALSE; op1 = (BaseObject* )linkbox1->GetLink(GetActiveDocument()); if(!op1) return FALSE;
linkbox2 = (LinkBoxGui\* )FindCustomGui(IDC_OBJECT2, CUSTOMGUI_LINKBOX); if(!linkbox2) return FALSE; op2 = (BaseObject\* )linkbox2->GetLink(GetActiveDocument()); if(!op2) return FALSE; GePrint("Object Name : " + op1->GetName()); GePrint("Object Name : " + op2->GetName()); break; case IDC_CANCEL: break; default: break; } return TRUE;
