Falloff example anyone?
    On 08/02/2012 at 03:45, xxxxxxxx wrote:
    Anyone have an example of falloff being used
    esp. in context with Mograph
    either way - any example appreaciated
    On 08/02/2012 at 04:03, xxxxxxxx wrote:
    There's a simple FalloffData example in the C++ SDK: RandomFalloff.
    On 08/02/2012 at 08:32, xxxxxxxx wrote:
    ummmm
    ta
    anyone else  - Python?
    On 08/02/2012 at 23:17, xxxxxxxx wrote:
    Tried to fiind some examples code in the C++ SDK as suggested
    Impossible to find - apart from definitions of  FallOff in SDK
    Anyone find anything at all on this subject that I can see working pls
    On 09/02/2012 at 01:09, xxxxxxxx wrote:
    RandomFalloff C++ example is located at "CINEMA 4D\plugins\cinema4dsdk\source\falloff\randomfalloff.cpp".
    I converted it to Python. It's very simple but if you're interested please email sdk_support@maxon.net and I'll send you the plugin files.
    On 09/02/2012 at 02:14, xxxxxxxx wrote:
    Sorry Yannick
    I misunderstood - I thought you meant there was an example in the documentation
    Much appreciated - will send email
    On 09/02/2012 at 07:55, xxxxxxxx wrote:
    @Yannick Why do we have to send an email to see this example?
    @deepshade currently working on an example, you can get it in a few hours.
    Cheers, Niklas
    |Edit: Ehm, random-falloff example, nice and pretty, but nowhere is documented how I should calculate the relations to actual point I should modify, somewhat more complex example, for example spherical falloff, would be much more helpful, because the random isn't actually helpful at all.  The C++ documentation doesn't say anything about how to calculate the correct point to sample relative to the effector.
    On 09/02/2012 at 09:41, xxxxxxxx wrote:
    Even the most important part is missing ******due to inadequate **documentation , here is an example of a FalloffData plugin, including handles and drawing.
    Download Py-FallOff Example_0_1.zip from Mediafire
    Cheers, Niklas
    On 09/02/2012 at 10:43, xxxxxxxx wrote:
    thanks to everyone
    I'm sure some reverse engineering is going to very useful. I was looking to investigate controlling falloff in the python effector - or more accurately falloff using a know object to base the matrix on.
    But it all helps fill in the gaps.
    I still can't (currently) see how to make this work like the xpresso falloff equivalent.
    I'm looking for a bit of 'universal' falloff code (all the current falloff options)
    and attach that to a null.
    Side note:
    I guess on any project there are going to be gaps. My suggestion would be to aim for at least a single 'working' code example in each 'major' topic.
    And get some sort of poll on what areas to put sample code in first
    Objects
    Points
    Polygons
    etc
    thanks again
    Paul
    On 28/02/2012 at 08:41, xxxxxxxx wrote:
    I'd be glad if some guy from Maxon could tell us how to correctly use the FallOffData.Sample method.
    Thanks,
    -Niklas
    On 28/02/2012 at 10:24, xxxxxxxx wrote:
    Hi Niklas,
    I contacted the developers on this.
    p vector given to Sample() is the clone local position. To get its global position multiply it by data.mat, the falloff matrix.
    On 29/02/2012 at 05:25, xxxxxxxx wrote:
    Thank you very much, Yannick! Could you put that on "your list" on things to be documented please? :) As far as I've seen it's missing in the Python as well as in the C++ SDK.
    -Niklas
    On 09/07/2012 at 16:59, xxxxxxxx wrote:
    I could do very well with an Falloff example....
    Can't get my head around it at all.
    My task is to simply use the FallOff for a PyEffector.
    Lennart
    On 10/07/2012 at 04:22, xxxxxxxx wrote:
    Maybe I shouldn't try to do things at 4am and get some sleep instead :).
    I'll look into the default PyEffector falloff example and see what I can get out of it.
    What I -was- doing was using a PyExpression Tag trying to transfer the
    ColorArray from one Cloner to another, that's where I get the error message
    that a "falloff must be present".
    Then I looked into the mograph.FalloffDataData to see if I could make it work.
    But maybe I am misunderstanding what FalloffDataData really is and
    it is not meant for the falloff from within a Cloner?
    In this particular case I ended up doing the ColorTransfer using a PyEffector,
    as I suppose it is the best way of doing it.
    Lennart
