On 03/02/2012 at 01:45, xxxxxxxx wrote:
If I want something in say - a mograph effector to run once
can I make a global ?? without assigning a value (as it would zero each time the script ran if I did)
The correct syntax and logic would be really helpful and I'm unsure of both - pls
the sort of thing I was trying to do........have no idea how to do this correctly advice pls
if global ------called Flag_something_done---- not assigned : ????? Do the operation Flag_something_done = 1
On 03/02/2012 at 05:40, xxxxxxxx wrote:
is_done = False def main() : global is_done if not is_done: # make it done ... is_done = True
But setting globals is IMHO not a good style. I prefer using mutable objects available from the global-scope.
data = type('', (), dict(is_done = False))() def main() : if not data.is_done: # make it done ... data.is_done = True
Originally posted by xxxxxxxx if global ------called Flag_something_done---- not assigned : ????? Do the operation Flag_something_done = 1
If you really want to make it dirty:
def main() : if not globals().get('is_done', False) : # make it done ... globals()['is_done'] = True
On 03/02/2012 at 06:46, xxxxxxxx wrote:
cheers Niklas
I prefer to keep things as correct as possible I like the idea behind the mutable object with global scope
On 05/02/2012 at 03:29, xxxxxxxx wrote:
Thanks for the info Niklas
And yes it works - but...
As far as the Python Effector is concerned it appears this method can't be used as the global is only set when the file is opened and first run
For the Effector it needs something that can process
'is this the same as the last past through'? if True - skip setting it
and its also unclear if the effector in Parameter mode is working differently from the effector in Full mode Can the same method be used for both
On 05/02/2012 at 09:31, xxxxxxxx wrote:
Could you please post what you have tried?
Cheers, Niklas
