Connecting an Icon to a plugin!
    On 28/01/2012 at 16:04, xxxxxxxx wrote:
    Hi guys,
    I downloaded a Free plugin earlier today, but it didn't come with an icon and I want to add it to my layout.
    How do I add or connect an icon to it to make it easier to identify and see in my layout.
    Any help would be much appreciated.
    Jim
    On 28/01/2012 at 16:44, xxxxxxxx wrote:
    You could put the icon as a TIFF file into the plugin's "res" folder. But you would have to know the correct filename (as the plugin author passes the icon filename to the register function), so it's no use ;-) He probably did not pass any filename anyway.
    On 29/01/2012 at 01:09, xxxxxxxx wrote:
    Thanks for the reply, it's much appreciated.  I leave it where it is in the plugin menu and use it from there.
    Thanks again
    Regards
    Jim
    On 29/01/2012 at 03:50, xxxxxxxx wrote:
    You can create a script that calls the plugin using the CallCommand function. You can add an Icon to the script and add it to your layout. Cheers
    On 29/01/2012 at 04:10, xxxxxxxx wrote:
    Thanks nux, didn't think of doing it that way.
    Much appreciated
    Jim
