Render into picture viewer without VolumeData
On 26/01/2012 at 03:15, xxxxxxxx wrote:
Cinema 4D Version:   13
Hi all,
As far as I know it's is possible to create a VideoPostData that is an external renderer and calls VolumeData::SkipRenderingProcess() in VideoPostData::Execute() at the stages VIDEOPOSTCALL_RENDER and VIDEOPOSTCALL_INNER. I have done some experiments and everything seems to work as advertised.
Unfortunately then, the C4D renderer has already created a duplicate of the document and built a VolumeData including the render geometry and acceleration structures. As I don't need that data it just uses up memory.
-> Is there a way to be able to render using the picture viewer, but without the creation of the render geometry?
Many thanks in advance. Cheers,
Marcus
On 26/01/2012 at 03:33, xxxxxxxx wrote:
The docs say this:
VIDEOPOSTCALL_RENDER - Render precalculation. VolumeData not yet completly accessible.
My interpretation is that if SkipRenderProcess() is called at VIDEOPOSTCALL_RENDER, this will prevent the VolumeData from being built. I'm relying on that behaviour for one of my plugins, but maybe I should check this again :-).
Best regards
/Filip
On 26/01/2012 at 16:44, xxxxxxxx wrote:
Thanks for the reply. That's what I thought first, too. But it shows, that the memory consumpton goes up quite a bit. So I had a closer look:
VolumeData::GetObjCount() already returns the correct number of objects, accumulating the polygon count, also returns the total number and you can even do ray intersection tests.
I think the only thing that is not done is the setup of the shaders, but I may be wrong here, too.
Marcus
On 26/01/2012 at 21:33, xxxxxxxx wrote:
Ok, I can answer my question myself: The code below "renders" a checker board into the picture viewer without creating a VolumeData.
By the way, the document pointed to by "vps->doc" is a copy of the scene document.
Marcus
RENDERRESULT ExternalRenderer::Execute(BaseVideoPost*   node,
                                       VideoPostStruct* vps)
    if (vps && vps->render)
        Render* render = vps->render;
        VPBuffer* buffer= render->GetBuffer(VPBUFFER_RGBA, 0);
        LONG width = buffer->GetBw();
        LONG height = buffer->GetBh();
        SReal *lineBuffer = bNew SReal[width * 4];
        for (LONG row = 0; row < height; ++row)
            if (row % 10 == 0)
               for (LONG col = 0; col < width; ++col)
                    if (((row / 10) & 1) ^ ((col / 10) & 1))
                        lineBuffer[col*4]   = 0.55;
                        lineBuffer[col*4+1] = 0.55;
                        lineBuffer[col*4+2] = 0.55;
                        lineBuffer[col*4+3] = 0.55;
                    else
                        lineBuffer[col*4]   = 0.45;
                        lineBuffer[col*4+1] = 0.45;
                        lineBuffer[col*4+2] = 0.45;
                        lineBuffer[col*4+3] = 0.45;
            buffer->SetLine(0, row, width, lineBuffer, 32, false);
            GeSleep(10);
        bDelete(lineBuffer);
        return RENDERRESULT_USERBREAK;
    return RENDERRESULT_OK;
On 27/01/2012 at 01:24, xxxxxxxx wrote:
Unfortunately animation rendering doesn't relly work with this method since we stop during the first frame. -> All the nice animation functionality of the picture viewer becomes unavailable 😞
If someone knows a better way, please let me know.
Thanks,
Marcus
