Getting Effector Unique ID
On 22/01/2012 at 03:34, xxxxxxxx wrote:
Starting from the cloner
I can pick up the effector list, then object, name and type
If I have two effectors of the same type, with the same name
how do I tell them apart
and access that unique data
(yes - this only picks the first effector in the list - will iterate later)
pls
    obj_0 = op[c4d.ID_USERDATA, 7]
    ef = obj_0[c4d.ID_MG_MOTIONGENERATOR_EFFECTORLIST].ObjectFromIndex(doc, 0)
    efname = obj_0[c4d.ID_MG_MOTIONGENERATOR_EFFECTORLIST].ObjectFromIndex(doc, 0).GetName()
    eftype = obj_0[c4d.ID_MG_MOTIONGENERATOR_EFFECTORLIST].ObjectFromIndex(doc, 0).GetType()
or do I get the Effector Object in the OM
and compare that against the returned parameter ef? to see if they match
