On 15/01/2012 at 08:09, xxxxxxxx wrote:
Started looking at adding and removing user data
I can see how to add and remove
now if I have this correct the remove relies on the number ID
obj.RemoveUserData([c4d.ID_USERDATA, 1])
But if a user has already added user data the number will not always start at one
2 Qs:
1 how do you get that number 2 how do you track the user data items that you add?
I've tried getting the number ID_USERDATA but with no luck
I can only get what I think is referred to as a tuple (1,15,0) and guessing this is reflects the user data (numerical index, type, ???)
thoughts appreciated
Paul
add a cube add user data select cube run script
import c4d from c4d import gui #Welcome to the world of Python def main() : c4d.CallCommand(13957); # Clear console doc = c4d.documents.GetActiveDocument() sel_obj = doc.GetActiveObject() id_with_bc = sel_obj.GetUserDataContainer() for id, bc in sel_obj.GetUserDataContainer() : print id, bc, bc[c4d.DESC_NAME], bc[c4d.ID_USERDATA] print " " print "is this the id", id_with_bc[0][0] if __name__=='__main__': main()
On 20/01/2012 at 02:51, xxxxxxxx wrote:
Hi Paul,
When we call AddUserData(), it returns a DescID (the tuple you are refering to) containing the identification data we can then send to RemoveUserData(). If the user data has not been added by our code, we can get the DescID by looping trough the user data container with GetUserDataContainer().
Here is an example showing how to deal with user data DescID, DesLevel, type etc.:
import c4d def AddLongDataType(obj) : if obj is None: return bc = c4d.GetCustomDatatypeDefault(c4d.DTYPE_LONG) # Create default container bc[c4d.DESC_NAME] = "Test" # Rename the entry element = obj.AddUserData(bc) # Add userdata container for i in range(0, element.GetDepth()) : print element[i].id # element[i] is a DescLevel object print element[i].dtype # element[0] is for c4d.ID_USERDATA # element[1] is for our user data print "Added user data : ", element[1].id obj[element] = 30 # Assign a value c4d.EventAdd() # Update def RemoveLongDataType(obj) : for element, bc in obj.GetUserDataContainer() : if element[1].dtype == c4d.DTYPE_LONG: if obj.RemoveUserData(element) : print "Removed user data : ", element[1].id # To remove the data we could also call: # obj.RemoveUserData(element[1].id) # obj.RemoveUserData([c4d.ID_USERDATA, element[1].id]) c4d.EventAdd() # Update def main() : AddLongDataType(op) RemoveLongDataType(op) if __name__=='__main__': main()
Yannick
