On 14/01/2012 at 01:13, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12 Platform: Language(s) :
--------- Hi, I'm Trying to get the selected Polygons of an object which where save into a polygon selection tag. My Plugin is a ObjectData Plugin and I've not found a way to get the Polygon selection. I've searched in this forum and found some stuff but it's not helping since i can't access the function GetPolygonSelection() and neither GetSelection. Is there a workaround?
On 14/01/2012 at 01:25, xxxxxxxx wrote:
It's easy enough:
SelectionTag *st; // first get the tag from the object // ... // check it's a poly selection: if(st->GetType() & Tpolygonselection)
BaseSelect *bs = st->GetBaseSelect();
Steve
On 16/02/2012 at 10:03, xxxxxxxx wrote:
It still wont work
SelectionTag st = SelectionTag.Alloc(C4dApi.Tpolygonselection); BaseSelect bs = st.GetBaseSelect(); bs.Select(3);/tried 0 1 2 3
I also set the cube as active object before the posted code. but as you can see the polygonselection isnt active its not selected. If it worked the top polygon should be selected.
On 16/02/2012 at 11:48, xxxxxxxx wrote:
If the end result you're trying to achieve is to execute the selections that are saved in your selection tags. Then you can do this with the DescriptionCommands(Those buttons in the tag's AM).
#include "../../resource/res/description/Tpolygonselection.h" BaseDocument *doc = GetActiveDocument(); BaseObject *obj = doc->GetActiveObject(); //Start out using BaseObject to grab the polygon object if(!obj) return FALSE; //Error Handling PolygonObject *pobj = ToPoly(obj); //Cast the BaseObject type to a PolygonObject type and assign it to a variable "pobj" if(!pobj) return FALSE; //Error Handling for(BaseTag* polyTag = pobj->GetFirstTag(); polyTag; polyTag = polyTag->GetNext()) //Search for a PolygonSelection type tag { if(!polyTag->IsInstanceOf(Tpolygonselection)) continue; polyTag->SetBit(BIT_ACTIVE); //optional... if you want the tag to be selected or not DescriptionCommand dc; //Create an empty DescriptionCommand variable to hold the command we'll use next dc.id = DescID(POLYGONSELECTIONTAG_COMMAND1); //Assigns the POLYGONSELECTIONTAG_COMMAND1 to the dc variable polyTag->Message(MSG_DESCRIPTION_COMMAND,&dc); //Execute the command }
The Tpolygonselection.h file shows the other buttons you can execute with code the same way.
On 16/02/2012 at 14:45, xxxxxxxx wrote:
I'm trying to achieve to create for each selected point a weight with the function SetWeight. So I figured the best way to do that would be a For loop. Where i check if the point is selected or not. If it is selected I set the weight else I do nothing. And it seems like this only work if the point are selected in the viewport. Of course i could be wrong.
SelectionTag st = SelectionTag.Alloc(C4dApi.Tpointselection); BaseSelect bs = st.GetBaseSelect(); PointObject pObj = PointObject.GetPointObject(op2); C4dApi.GePrint("test"+bs.Select(0)); bs.Select(0); BaseSelect SelectedPoints = pObj.GetPointS(); for (int i = 0; i < pObj.GetPointCount(); i++) { if (SelectedPoints.IsSelected(i)) { this.wtagGlob.SetWeight(1,i,0.04); C4dApi.GePrint("Der Punkt mit dem Index " + i + " ist selektiert"); } }
thats my idea
On 17/02/2012 at 01:41, xxxxxxxx wrote:
I don't understand why you're allocating a new tag. The tag you need is already on the object, unless I've misunderstood you completely. What you need to do is get a pointer to the tag from the object and get that tag's BaseSelect.
What you're actually doing is allocating a new tag and getting its BaseSelect which, not surprisingly, is empty.
Also, the selection you get from GetPointS() is not the same as the selection in a selection tag. You can have a stored selection in the tag but quite different points currently selected in the model. That's why in your code nothing happens unless you have points selected in the viewport.
