Selecting Only Merged Objects
On 28/12/2011 at 07:21, xxxxxxxx wrote:
Hello everyone,
I am trying to select merged objects using python.
What I want to be able to do is select only the merged objects in the scene and then run a "center object axis" command on them.
I was able to get the objects to merge but I can't select only the merged objects. I don't want to select all, but only the objects that I have merged.
Your help would be much appreciated.
bellow is my code:
from c4d import gui
#Welcome to the world of Pythondef main() :
path="Temp/temp.obj"
c4d.documents.MergeDocument(doc, path, 1);
c4d.CallCommand(1011982);
c4d.EventAdd();
if __name__=='__main__':
Thank you :)Anand
