(newbee) Python versus COFFEE
On 16/12/2011 at 02:00, xxxxxxxx wrote:
Hi there,
I am new to scripting in C4D but I am fluent in Python. So I thought Python is probably the way to go.
However, it appears to me that the SDK API is underexposed in Python, compared to COFFEE, at least looking at the documentation API : Is there anybody to confirm or to invalidate that ?Exemple.
I have to create a bunch of plane objects, and of each of them, a new material (with color and alpha channel).At first this simple script fails (error is raised) :
import c4d from c4d import * def main() : mat = BaseMaterial(Mmaterial) mat.setChannelState(CHANNEL_ALPHA, True) if __name__=='__main__': main()
AttributeError: 'c4d.BaseMaterial' object has no attribute 'setChannelState'. Which is quite expected since the setChannelState method is declared only for subclass Material derived from BaseMaterial, but guess what, when I use Material it says that the Material symbol is not defined (despite the "from c4d import *").
What's wrong ? I simply need to crearte a new material and apply it to a freshly created plane object.
Secondly, is there any Python code snippets or samples web site where one can learn by examples ?
I find the COFFEE API better documented that the Python one.Thank you for your help,
Elie
Exemple.
At first this simple script fails (error is raised) :import c4d from c4d import * def main() : mat = BaseMaterial(Mmaterial) mat.setChannelState(CHANNEL_ALPHA, True) if __name__=='__main__': main()
What's wrong ? I simply need to crearte a new material and apply it to a freshly created plane object.Material class is deprecated as stated in this post. I have to put this note in the docs.
So the code could be:import c4d from c4d import * def main() : mat = BaseMaterial(Mmaterial) print mat[MATERIAL_USE_ALPHA] mat[MATERIAL_USE_ALPHA] = True print mat[MATERIAL_USE_ALPHA] if __name__=='__main__': main()
Note: Python is case-sensitive and you were calling 'setChannelState' (declared 'SetChannelState'), so anyway it won't even find the method.
I find the COFFEE API better documented that the Python one.Have you looked at the examples included in the docs ?
Searching this forum is a good way to find answers.Python documentation is pretty young compared to the COFFEE one. I plan to greatly improve it in the future.
Regards,
On 16/12/2011 at 09:58, xxxxxxxx wrote:
Hello Yannick,
Thank you for your prompt answer that helped a lot. The python dictionnary approach to feed the parameters is really convenient.Yes the doc is a bit weak at least for beginners. But fortunately making massive use of google and using this forum helps a lot.
I must say that this folder is a knowledge mine that would gained to be documented with example of use in context (constant names) :
/Applications/MAXON/CINEMA 4D R13/resource/res/descriptionFor others that may have the same need, here is the testing code I used to create a material, a plane and assign the material as a texture to the plain.
Elieimport c4d import math from c4d import * def creatMat(matname) : #create a standard material mat = c4d.BaseMaterial(c4d.Mmaterial) #create a bitmap shader for color xch = c4d.BaseList2D(c4d.Xbitmap) #set the path of the image file to the bitmap shader xch[c4d.BITMAPSHADER_FILENAME] = "/Users/semiosys/Desktop/fleurbleue.tif" #set the shader to the color channel mat[c4d.MATERIAL_COLOR_SHADER] = xch mat.InsertShader(xch) #create a bitmap shader for color axch = c4d.BaseList2D(c4d.Xbitmap) #set the path of the image file to the bitmap shader axch[c4d.BITMAPSHADER_FILENAME] = "/Users/semiosys/Desktop/fleurbleue_mask2.tif" #set the shader to the color channel mat[c4d.MATERIAL_ALPHA_SHADER] = axch mat.InsertShader(axch) mat[c4d.MATERIAL_USE_ALPHA] = 1 mat[c4d.MATERIAL_USE_SPECULAR] = 0 mat[c4d.ID_BASELIST_NAME] = matname # UVW projection mat.Message(c4d.MSG_UPDATE) mat.Update(True, True) doc.InsertMaterial(mat) return mat def main() : neutre = BaseObject(Onull) mat = creatMat("PETAL"); plane = BaseObject(Oplane) plane.InsertUnder(neutre) plane[c4d.PRIM_PLANE_WIDTH] = 1000; plane[c4d.PRIM_PLANE_HEIGHT] =1000; plane[c4d.PRIM_PLANE_SUBW] = 10; plane[c4d.PRIM_PLANE_SUBH] = 10; plane[c4d.PRIM_AXIS] = 0; plane[c4d.ID_BASELIST_NAME] = "planperso2"; plane[c4d.ID_BASEOBJECT_REL_POSITION] = Vector(10,10,10) plane[c4d.ID_BASEOBJECT_REL_SCALE] = Vector(1,1,1) doc.InsertObject(plane) # Flip horizontal plane[c4d.ID_BASEOBJECT_REL_ROTATION] = Vector(math.pi,0,0) tag = c4d.TextureTag() tag[c4d.TEXTURETAG_MATERIAL] = mat tag[c4d.TEXTURETAG_PROJECTION]=6 #print tag[c4d.TEXTURETAG_MATERIAL].GetName() tag[c4d.ID_BASELIST_NAME] = tag[c4d.TEXTURETAG_MATERIAL].GetName() plane.InsertTag(tag) c4d.EventAdd() if __name__=='__main__': main()
