GetGenerator() equivalent in a Python Effector
On 11/12/2011 at 18:39, xxxxxxxx wrote:
Greetings to all.
Question: does anyone know of a GetGenerator() equivalent for a Python mograph effector?
Ultimately, I need to be able to figure out how many children are located under a Cloner object, within the effector itself. I need that number to determine the relevant data to feed to MODATA_CLONE to control the index of an object cloned by the cloner. The problem here is that the cloned objects are < then the number of objects parented to the cloner, so GetCount() doesn't do anything for me.
COFFEE at least has the aforementioned GetGenerator() function and I'm sure you can use that to derive the number of children under the cloner object. However Python doesn't appear to have this function.
So... What is the best way to figure out the cloner object (so I can in turn figure out how many children it has) from a Python effector?
-CMPX
On 18/01/2012 at 04:40, xxxxxxxx wrote:
Just to bump this
From what I can see there no connection between a PY Effector and the Cloner(s) that is/are using it?
Can we get an answer on this one please either way - as the OP was early December.
On 19/01/2012 at 03:58, xxxxxxxx wrote:
OK Apart from going through the cloners - checking their effector list to see if it is using the Python effector
is there any other way of getting the Cloner object the effector is attached to?
On 23/01/2012 at 08:31, xxxxxxxx wrote:
is there any other way of getting the Cloner object the effector is attached to?GetGenerator() is missing in the Python API and will be implemented in the future.
Meanwhile, the best workaround is to add a Link user data to the Python Effector and connect the Cloner.
Then in the Python effector code you could call:cloner = op[c4d.ID_USERDATA, 1] print cloner
On 23/01/2012 at 08:43, xxxxxxxx wrote:
Thanks for the feedback Yannick
but I think this will be a problem if you use the effector in more than one cloner
ie an unspecified number of cloersI'm thinking
search OM for cloners
check effector list
am I in there?
But I think this will be a problem if you use the effector in more than one cloner
ie an unspecified number of clonersYou can create as many Link user data as cloners.
I'm thinking
check effector list
am I in there?Yes, meanwhile this solution may be the best for complex situations.
On 24/01/2012 at 01:52, xxxxxxxx wrote:
Sebastian just told me that in the Python effector scope there's a variable called "gen"... So we can access the cloner object with this variable.
On 24/01/2012 at 07:25, xxxxxxxx wrote:
A quick example would save a lot of guesswork pls
On 24/01/2012 at 07:42, xxxxxxxx wrote:
Basically, 'gen' is the name of a variable (referencing the cloner or generator object) added to the execution of main() function in a Python effector, just as the same as 'doc' (document where the effector resides) and 'op' (effector) variables:
import c4d from c4d.modules import mograph as mo #Welcome to the world of Python def main() : md = mo.GeGetMoData(op) if md==None: return 1.0 # Print variables added to the scope of main() print op print gen print doc index = md.GetCurrentIndex() mode = md.GetBlendID() if mode==c4d.ID_MG_BASEEFFECTOR_POSITION: return c4d.Vector(0.5) else: return 1.0
On 24/01/2012 at 07:55, xxxxxxxx wrote:
Ah - I see
got it
place in a Python Effector and run
On 24/01/2012 at 09:01, xxxxxxxx wrote:
bingo, that works.
try again, deepshade.
( I think you're still working on a python version of d_PolySize.)
I just tried :cloneobj = gen[c4d.MG_OBJECT_LINK]
print cloneobjand it does return the Object the Cloner's cloning onto correctly,
although it gets funky when there's multiple cloners referencingthe same Effectorthanks, yannick
On 24/01/2012 at 12:13, xxxxxxxx wrote:
multiple cloner issue here too
douwe - re: d_PolySize - still getting stuck on the coffee poly manipulation
can you annotate to make conversion (a little) easier
Why
When the python effector is set to Full Control
does GEN returns the Clonerand
when the python effector is set to Parameter Control
does GEN returns the Cloner Object Link
On 10/02/2012 at 12:12, xxxxxxxx wrote:
or to put it another way
is the variable GEN in parameter mode
returned incorrectly ie a bugIf there is a difference - can someone explain why pls - as there is no documentation of the modes working differently other than (from what I can see) the parameter version appears to be hooked to refresh once for every clone count
