On 07/12/2011 at 15:08, xxxxxxxx wrote:
User Information: Cinema 4D Version: Python Platform: Language(s) :
--------- HairGuides.SetPoint(id, p) has the same explanation as GetPoints() "Gets a list of points for the guides." This is of course wrong.
HairGuides.GetPoints() is also listed twice in the R13 sdk.
Concerning the rest of the SDK and Hair. There's not much there. There isn't even an explanation on how to create hair objects and guides. So here's an example I put together:
import c4d def main() : obj = c4d.BaseObject(c4d.Ocube) #Creates a Cube in memory only doc.InsertObject(obj) #Adds it to the OM ho = c4d.BaseObject(1017305) #Creates a hair object in memory only ho[c4d.HAIRSTYLE_LINK]= obj #Puts the cube into the hair's link field doc.InsertObject(ho) #Adds it to the OM c4d.DrawViews(c4d.DRAWFLAGS_ONLY_ACTIVE_VIEW|c4d.DRAWFLAGS_NO_THREAD|c4d.DRAWFLAGS_NO_REDUCTION|c4d.DRAWFLAGS_STATICBREAK) #forces redraws ho = doc.SearchObject("Hair") #Lost the focus upon creation so we need to get it again guides = ho.GetGuides() #Assign the guides to a variable gcount = guides.GetCount() #Gets the number of guides print gcount segcount = guides.GetSegmentCount() #Number of segments per guide (number of points is one more than this) print segcount gpcount = guides.GetGuidePointCount() #Gets the number of points per segment. print gpcount owner = guides.GetObject() #Gets the guides owner object print owner.GetName() pnts = guides.GetPoints() #Gets a list of the points on all of the guides. print pnts guides.SetPoint(17, p= c4d.Vector(0,500,0)) #Moves one of the hair points to this vector position ho.SetGuides(guides,clone=False) #Error:The object doesn't own the guides!! Really?..Then who does? c4d.EventAdd() if __name__=='__main__': main()
I'm not sure what's going on with the SetGuides() function. In C++ the hair object owns the guides. And the python SDK also says the same thing. Yet I get an error that the hair object doesn't own the guides in my code. I'm not sure if that's a real bug. Or another one of those things that's documented clearly.
On 07/12/2011 at 23:29, xxxxxxxx wrote:
Hi, the guides already belong to the hair object. Cheers, Sebastian
On 08/12/2011 at 08:22, xxxxxxxx wrote:
Hi Sebastian,
That's kinds of a strange error message. It might be better to change it if possible. So does that mean that SetGuides() is only supposed to be used within python plugins?
Also. When I change a guide hair's point position with: guides.SetPoint(17, p= c4d.Vector(0,500,0)). The point doesn't move(update) until I toggle the hair on&off in the OM. I've tried things like: c4d.DrawViews(c4d.DRAWFLAGS_FORCEFULLREDRAW) but none of them are working for me.
