InitRenderStruct
    On 10/11/2011 at 21:46, xxxxxxxx wrote:
    Cinema 4D Version:   R13
    Platform:   Windows  ;
    I used CustomDataType Gradient in VideoPostData's Execute function.
    Now R13, Gradient->InitRender function requires InitRenderStruct.
    How can I get InitRenderStruct in VideoPostData's Execute function?
    Best regards,
    Takamitsu
    On 11/11/2011 at 01:38, xxxxxxxx wrote:
    In this case you have to initialize the InitRenderStruct with the current document and assign the volume data manually:
    if (!vps->doc) return RENDERRESULT_OUTOFMEMORY;
    InitRenderStruct irs;
    // Initialize the InitRenderStruct with the infos from the document
    irs.Init(vps->doc);
    // Assign the volume data of the VideoPostStruct to the InitRenderStruct volume data
    irs.vd = vps->vd;
    Tell me if this work for you.
    On 11/11/2011 at 03:07, xxxxxxxx wrote:
    Thank you for your help!
    It was able to do well by the method.
