On 07/11/2011 at 02:45, xxxxxxxx wrote:
Here a Newbee-Question:
I have to do repeating several changes in a projekt like: --- select al polygon objects change to point-mode selekt all points optimice --- or --- select al polygon objects change to polygone-mode selekt all polygons untriangulate --- or --- select all UV-Tags delete all selected Tags
Now my Question: What ist the best way to solve the problem? Phyton or Coffee Does anybody have an example for the problems at the top.
Thanks
On 07/11/2011 at 05:44, xxxxxxxx wrote:
Hi Ronald,
I think you should use the "Script Log" (located in the "Script" menu). Its help page ("Script Menu" -> "Script Log") contains useful information on how to use it. This editor allows you to write a Python script just by recording the actions you perform in CINEMA 4D. Just like a macro recorder.
For example I get the following Python code when I create a Cube Make the cube editable Activate Points mode Call optimize on the cube
import c4d from c4d import documents, plugins #Welcome to the world of Python def main() : c4d.CallCommand(5159) # Cube c4d.CallCommand(12236) # Make Editable c4d.CallCommand(12139) # Points c4d.CallCommand(14039) # Optimize... if __name__=='__main__': main()
Yannick
On 07/11/2011 at 06:36, xxxxxxxx wrote:
Hi Yannick,
thanks for your replay. My main-problem is not to find the "CallCommand"! My main-problem is to select all polygon objects or a normal-tag. There must be a way to select all and than proceed a modification like delete! Does anybody out there kow a way to select all polygon-objects??
Thanks a lot
On 07/11/2011 at 07:52, xxxxxxxx wrote:
It might help to go to my website and download the CoffeeBible:https://sites.google.com/site/scottayersmedia/scripting
It could use another update. But I've stopped updating it because Coffee is fading. And Python is taking over. But it's full of things like grabbing objects, points polygons, etc.. and lots of other common tasks that might help you get started.
