Accessing MoText Group Parameters
On 03/11/2011 at 19:45, xxxxxxxx wrote:
Cinema 4D Version: 13
Platform: Windows ; Mac OSX ;
The Transform parameter IDs under each MoText group (Lines, Words etc) are identical.If I want to access e.g. Transform position values under the Lines group, it looks as if I need to use the group ID 'MGTEXTOBJECT_GROUPTRANSFORM_LINE' in conjunction with 'ID_MG_TRANSFORM_POSITION'.
How do I do this?
On 05/11/2011 at 14:46, xxxxxxxx wrote:
Perhaps some more detailed information is needed.
The Transform tab Scale value for a Cloner can be accessed with:
BaseContainer *bc = gen->GetDataInstance(); if(!bc) return; Vector scale = bc->GetVector(ID_MG_TRANSFORM_SCALE); GePrint("scale: " + VectorToString(scale));
In a MoText, ID_MG_TRANSFORM_SCALE can't be accessed directly as the same ID is used under four different groups.
Using the Letters group as an example, omograph_text.res has this:
GROUP MGTEXTOBJECT_GROUPCHAR
SCALE_V;
GROUP
COLUMNS 2;
SCALE_V;IN_EXCLUDE MGTEXTOBJECT_EFFECTORLIST_CHAR
SCALE_V;
SCALE_H;
NUM_FLAGS 1;
INIT_STATE 1;
IMAGE_01_ON 1018640;
IMAGE_01_OFF 1018641;
ACCEPT
Obaseeffector;
STATICTEXT { JOINEND; }VECTOR MGTEXTOBJECT_AXIS_CHAR
UNIT PERCENT;
MIN 0.0;
MAX 100.0;
CUSTOMGUI VECTOR2D;
BOOL MGTEXTOBJECT_AXIS_CHAR_ALIGN
GROUP MGTEXTOBJECT_GROUPEFFECTOR_CHAR
}MGTEXTOBJECT_GROUPEFFECTOR_CHAR appears to correspond with the Transform parameters. omograph_text.h also lists MGTEXTOBJECT_GROUPTRANSFORM_CHAR. I'm not sure which to use or how many levels are involved.
I've tried various subcontanier and DescLevel operations to no avail.
Could someone please provide assistance?
On 07/11/2011 at 15:00, xxxxxxxx wrote:
I'd like to bump this because there does seem to be a problem with it.
The transformation panels inside of the MoText object seem to only be accessible though xpresso.C++ example :
#include "..\..\..\modules\mograph\res\description\otransform_panel.h" #include "..\..\..\modules\mograph\res\description\omograph_text.h" GeData d; obj->GetParameter(DescID(ID_MG_TRANSFORM_SCALE, VECTOR_X), d, (DTYPE_VECTOR, DESCFLAGS_GET_0)); //Result is always zero obj->SetParameter(DescID(ID_MG_TRANSFORM_SCALE, VECTOR_X), GeData(5.0), DESCFLAGS_SET_0); //No errors..But no changes are executed
Coffee Example :
var obj = doc->GetActiveObject(); //The MoText object is active obj#ID_MG_TRANSFORM_SCALE:VECTOR_X = 1;//Invalid description ID
Python Example :
import c4d def main() : obj = doc.GetActiveObject() #The MoText object is active obj[c4d.ID_MG_TRANSFORM_SCALE,c4d.VECTOR_X] = 1 #__setitem__ got unexpected type 'int' c4d.EventAdd() if __name__=='__main__': main()
I'm still learning this stuff. So I'm probably wrong about this.
But It sorta looks like they were never added to the API's?-ScottA
On 08/11/2011 at 01:30, xxxxxxxx wrote:
Thanks for taking the time to do some testing Scott.
The problem with using ID_MG_TRANSFORM_SCALE in this way is that the same ID is used for independent parameters under the All, Lines, Words and Letters groups. A higher-level ID from omograph_text.h has to also be used.
On 08/11/2011 at 07:45, xxxxxxxx wrote:
Did you figure it out David?
I did also try using higher ID's in a bunch of different ways. But I still couldn't get it to work.example:
obj->SetParameter(DescID(MGTEXTOBJECT_GROUPLINE, ID_MG_TRANSFORM_SCALE,VECTOR_X), GeData(15.0), DESCFLAGS_SET_0); //Does not work
On 09/11/2011 at 03:53, xxxxxxxx wrote:
No, unfortunately I don't have a solution Scott.
Apparently neither do any of the other developers here or Maxon support.
On 09/11/2011 at 06:08, xxxxxxxx wrote:
Sorry for the delay. I asked the developers and will post the solution if there is one.
cheers,
Matthias
On 09/11/2011 at 14:19, xxxxxxxx wrote:
Thanks Matthias. At least I know I'm not missing something obvious.
On 10/11/2011 at 06:38, xxxxxxxx wrote:
You need to use the following group offset to obtain the final ID.
MGTEXTOBJECT_GROUPTRANSFORM_ALL MGTEXTOBJECT_GROUPTRANSFORM_LINE MGTEXTOBJECT_GROUPTRANSFORM_WORD MGTEXTOBJECT_GROUPTRANSFORM_CHAR
Simply add transform ID and group offset ID for the final ID.
Example:
GeData d; if (op->GetParameter(DescLevel(ID_MG_TRANSFORM_POSITION + MGTEXTOBJECT_GROUPTRANSFORM_LINE),d,DESCFLAGS_GET_0)) { GePrint(RealToString(d.GetVector().x)); }
cheers,
Matthias
On 10/11/2011 at 07:48, xxxxxxxx wrote:
Thanks Matthias.
Sorry for being so dense. But I still can't get the SetParameter() to work with your example:
obj->SetParameter(DescID(ID_MG_TRANSFORM_POSITION, VECTOR_X + MGTEXTOBJECT_GROUPTRANSFORM_LINE), GeData(0.3), DESCFLAGS_SET_0); //Does not change
And what about the scripting languages?
This plus sign thing doesn't seem to work with them for me either.-ScottA
*Edit- I managed to figure out a way to get it to work:
BaseObject *obj = doc->GetActiveObject(); //The MoText object is active GeData d; //A variable to hold the parameters if (obj->GetParameter(DescLevel(ID_MG_TRANSFORM_POSITION + MGTEXTOBJECT_GROUPTRANSFORM_LINE),d,DESCFLAGS_GET_0)) { GePrint(RealToString(d.GetVector().x)); //Print the x Position value Vector newV = Vector(5,0,0); //Create a new vector position value d.SetVector(newV); //Set the vector parameter held in variable d to this new vector value in memory only obj->SetParameter(DescID(ID_MG_TRANSFORM_POSITION + MGTEXTOBJECT_GROUPTRANSFORM_LINE), GeData(newV), DESCFLAGS_SET_0); //Execute the vector change from memory GePrint(RealToString(d.GetVector().x)); //Print the new x Position value }
Still trying to figure out how to use this with Coffee & Python.
On 11/11/2011 at 05:00, xxxxxxxx wrote:
Works like a charm, thanks again Matthias.
