Texture change python
    On 26/10/2011 at 08:54, xxxxxxxx wrote:
    Hi there,
    Is there a way to change the texture in the color channel of a material using python.
    Currently i'm writing a script where there is a variable on my clipboard wich is used to build up a document.
    If my question isn't clear, let me know.
    Much thanx in advance.
    Kind regards RNE
    Script so far:
    from c4d import gui, bitmaps, documents
    c4d.StopAllThreads()
    c4d.StatusSetSpin()
    c4d.StatusSetText("Starting script")
    datanaam = c4d.GetStringFromClipboard()
    c4d.CallCommand(1024314) # Clear Python Log
    c4d.CallCommand(1022604) # Open Python Log
    klaar maken om te renderen
    doc = documents.GetActiveDocument()
    rd = doc.GetActiveRenderData()
    instellen van de rendersettings op basis van de texture
    c4d.StatusSetText("Adjusting render settings")
    currpath=''+rd.GetDataInstance()[c4d.RDATA_MULTIPASS_FILENAME]
    currpath=''+doc[c4d.DOCUMENT_PATH]+'/'
    rd[c4d.RDATA_MULTIPASS_SAVEIMAGE] = 1 # 1=aan 0=uit
    rd[c4d.RDATA_MULTIPASS_FILENAME] = r''+currpath+"Renders/"+datanaam+'.psd'
    #changing the texure
    #save the current document as a c4d file
    c4d.documents.SaveDocument(doc, currpath+"CinemaFiles/"+datanaam+".c4d", c4d.SAVEDOCUMENTFLAGS_DIALOGSALLOWED, c4d.FORMAT_C4DEXPORT)
    lijst=c4d.documents.GetBatchRender()
    lijst.AddFile(currpath+"CinemaFiles/"+datanaam+".c4d",0)
    c4d.documents.BatchRender.Open(lijst)
    c4d.StatusSetText("Added to renderlist")
    c4d.documents.CloseAllDocuments()
    c4d.CallCommand(465003513); # start render queue
    On 26/10/2011 at 18:07, xxxxxxxx wrote:
    The thought process is as follows:
    -Get the material you want to change by whatever means you prefer(if Active, It's name, etc.).
    -Create a new Xbitmap shader to hold your texture image.
    -Tell that Xbitmap shader where to find the texture image using file paths.
    -Insert that Xbitmap shader into the color channel of the material.
    This example will insert the image named "myimage.jpg" from your desktop into the color channel of the currently active material:
    import os
    def main() :
      fn = c4d.storage.GeGetC4DPath(c4d.C4D_PATH_DESKTOP) #Gets the desktop path
      pathToTexture = os.path.join(fn,'myimage.jpg')      #Gets the specific texture image on your desktop
      mat = doc.GetActiveMaterial()                       #Assign the active material a variable
      shdr_texture = c4d.BaseList2D(c4d.Xbitmap)          #Create a bitmap shader in memory
      shdr_texture[c4d.BITMAPSHADER_FILENAME] = pathToTexture #Assign the path to the texture image to your shader
      mat[c4d.MATERIAL_COLOR_SHADER]= shdr_texture        #Assign the shader to the color channel in memory only
      mat.InsertShader(shdr_texture)                      #Insert the shader into the color channel
      mat.Update(True, True)                              #Re-calculate the thumbnails of the material
    if __name__=='__main__':
    On 27/10/2011 at 01:50, xxxxxxxx wrote:
    Big thanx ScottA
    Now I can't find any documentation on how to select a material by its name.
    Can you please help me out. mat = doc.GetMaterial doesn't work ?
    Kind regards RNE
    On 27/10/2011 at 03:13, xxxxxxxx wrote:
    To get a material by name, there is doc.SearchMaterial(name).
    On 28/10/2011 at 04:22, xxxxxxxx wrote:
    Thanx a lot, this works great.
