Python Libraries (eg Numpy, PIL etc...) & Cinema4D
On 23/10/2011 at 04:57, xxxxxxxx wrote:
Hi there,
I'm looking at creating a python generator that's using some python Libraries (NumPy, SciPy, PIL and MatPlotLib). I've got the effect already coded up in python and its working as expected, however I'm now looking at integrating this with Cinema4D.
The problem is that Cinema4D uses its own python installation, and the libraries I'm using aren't installed with Cinema4D's version of python. How would I go about setting Cinema4D up with a library such as NumPY ?
Thanks,
-Matt
On 23/10/2011 at 08:08, xxxxxxxx wrote:
Download the appropriate Installer of NumPy (for Python 2.6) and choose the Python installation of C4D for installation.
But note that there are some problems when using 3rd party packages, especially C extensions.- 32 Bit and 64 Bit must be installed seperately - Most C packages do not support 64 bit - The user using your plugin must install the 3rd party package
I'm sure there are some more, just to point out the most important ones.
Locations that might interest you:
Python binary location: .../MAXON/Cinema 4D/resource/modules/python/res/PythonXXX.framework Python extension locations (win / don't know on mac) : %APPDATA%/MAXON/Cinema 4D/library/python/XXX/
Cheers, Niklas
On 23/10/2011 at 12:29, xxxxxxxx wrote:
I expected as much on the 64bit side of things.
Thanks for the pointers, I'll give it a go tomorrow I think.
-Matt
On 17/04/2015 at 02:26, xxxxxxxx wrote:
i still cant in install numpy for c4d
it showsPython version2.6 required, which was not found in the registry
but i cant change the directory of numpy installation
On 27/04/2015 at 05:07, xxxxxxxx wrote:
You cannot use the default installer because C4D is not registered as a Python environment in your system. If you have a Python-2.6 installation on your system you can use it as a target and copy the files over to the Python directory of C4D, unless the package contains C-modules (which is for example the case for Numpy).
In that case you can't use the official installer of Numpy either because it was compiled with a different compiler. For Python the compilers must match exactly and therefore the only way to run Numpy properly in C4D is to compile it by yourself with Visual Studio 2010 (including all updates).
On 27/04/2015 at 05:40, xxxxxxxx wrote:
I've got a compiled version of Numpy 1.9.1. You can download it from my Website: http://blog.niklasrosenstein.com/2015/04/numpy-in-cinema-4d/
On 28/04/2015 at 05:43, xxxxxxxx wrote:
Cool! Thanks
-b
On 28/04/2015 at 22:51, xxxxxxxx wrote:
I can't download it.
It says: Oops! That page can't be found
On 02/05/2015 at 11:18, xxxxxxxx wrote:
Links are working now for: NumPy, Scipy, Cython
Thanks a lot Nicklas!
On 04/05/2015 at 04:59, xxxxxxxx wrote:
Hello
About CythonHas anybody such issue with Compiling with
cython.inline
> http://docs.cython.org/src/reference/compilation.html#compiling-with-cython-inline
It can not find vcvarsall.bat in c4d (having of vs2012). I try different modes, even simply return file with arch=x64
For example i can compile from pyx files in cmd or from bat file
On 04/05/2015 at 06:09, xxxxxxxx wrote:
To compile with Cython you need the same setup as to compile any C Extension for Python.
On 04/05/2015 at 06:35, xxxxxxxx wrote:
Hello Niklas. Thank you. I build pyd slightly differ
Yeah i do it, search over net, i found trick, that adding sys environment VS90COMNTOOLS = %VS110COMNTOOLS% . I was very unmindful
(without any mods in lib dir/pyDir or continuously adding of environment variables in pycode)so we get inline codinig, closer in houdini
